Click for Westport Click for JetForums Click for Glendinning Click for Burger Click for Northern Lights
Incredible Illusionist!!!
Discussion in 'YachtForums Yacht Club' started by YachtForums, Mar 31, 2010.
  2. Arniev
    Arniev Senior Member
    Monterey, CA, USA
    Hey, Carl!
    How the heck did he do that?
    Arnie
  3. YachtForums
    Hi Arnie,
    Beats me. I'm starting to think this stuff is real! Between Chis Angel, David Blaine and digital technology, it's all beginning to blend into belief.
  4. Savasa
    Savasa Senior Member
    Iqaluit, Nunavit, Canada
    Methinks the Philadelphia experiment?????
  5. Ward
    Ward Senior Member
    Vancouver BC
    I'm pretty sure the first couple were done with magnets - I bet his ring is magnetic and the coins might be made in a way to stick together so that two coins can become one.
    But the third one... No idea how he could hide a hole or a soft spot in the table.
  6. MaxPower
    MaxPower Senior Member
    At Sea ... Aahhh ...
    amazing ... very well done ...
  7. MaxPower
    i saw a show on tv in which they disclose magician's secrets ...
    the only parallel that comes to mind is where the table top (an acrylic/hard plastic of some sort) is NOT a single sheet ... thus 2 sheets slide in opposite directions opening a hole for his arm ...
    note that he covers the hole with his other palm ...
    & that the camera moves down to table level to prevent you from seeing the dual sheets which would obviously be evident at the time ...
    my 0.02¢ worth ...
  8. NYCAP123
    Ah the Masked Magician. He does another where he throws a deck of cards at a glass window depositing one card on the other side of the glass. It's very interesting to see the secret, but the mystery is definitely more fun. This fellow puts on a good show right down to his facial expressions. Even transcends language. Very entertaining.
  9. Fireman431
    Fireman431 Senior Member
    East central Florida
    Very simple on all 3 tricks. He's a warlock. :D
  10. MaxPower
    bingo!
  11. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    China has a grand tradition of magic but I think I've worked out the 2nd trick.
    Where the 3 coins are laid out, it is possible to hide a di-polar magnetic pair of discs in a foil coating. Thus when he thumps the table from below, the 2 discs conjoin by magnetic attraction and a palmed coin falls into the bowl.
    Oh blast! I see April the 1st was yesterday.
    Haven't the foggiest how he did it. :confused:
  12. outfitting
    outfitting New Member
    Den Bosch
    tricks
    It is obviously that he already has the coin in his hand underneath the glass panel....for the first 2 tricks...
    The third trick,..... why holding your hand in front of the arm and why sliding that hand/arm over the glass first? Turning the glass panel in position...I suppose
    very well done.... that is for sure
  13. Arniev
    Monterey, CA, USA
    Yes, that's probably how he did it.
    Or, the acrylic/hard plastic had a slit where he could put his hand through.
    And as you mentioned, he covers the hole with his other palm.
    And, prior to this, he taps the table -around- the area where he later on puts his hand through, -not- on the spot itself.
  14. NYCAP123
    I think you'll find that the key to the illusion is in the black cloth that he continually cleans the table with. It would most likely contain filler to obliterate the seam in the panel after he opens and closes it. So much less mystifying and romantic when you analyze it though.
  15. Fishtigua
    Guernsey/Antigua
  16. MaxPower
    seen this before ... but my favourite magician is still criss angel a.k.a. mindfreak ... this guy is truly outstanding ...
  17. Fishtigua
    Guernsey/Antigua
    This is a good time-waster channel. Some interesting tricks and illusions.
    Try the duct-tape one yourself.
    brusspup - YouTube
  18. Fishtigua
    Guernsey/Antigua
  19. Fishtigua
    Guernsey/Antigua
  20. MaxPower
    nicely done ...
