Click for Northern Lights Click for Westport Click for Burger Click for YF Listing Service Click for Delta
Imron Paint touch-up
Discussion in 'Carver Yacht' started by trmnewt, Jan 18, 2014.
  1. trmnewt
    trmnewt Member
    Rochester
    Hi all, have a question. I have a Carver 506, and the framing around he wing doors and windows, as well as the side exit doors, is painted aluminum. I'm assuming it is Imron, but not sure. Anyway, in some areas the paint is bubbling or has peeled off. How do I touch it up? Is it a DIY job, or should I hire it done? How do I find out what he color is so I can match it? Does it have to be sprayed on, or can I touch it up with a brush? Any advice/tips would be most appreciated!
  2. timjet
    timjet Member
    Tampa, FL
    You might try Interlux's forum, I've found them helpful and informative. They make a one and two part poly that should work.
  3. dennismc
    dennismc Senior Member
    Vancouver BC
    The prep is 90% of the success or failure of the paint on aluminum..
    I wouldn't touch it up. If it's peeling in some area's, it will sooner than later peel in others. I would strip the entire door frame down to the bare metal. Apply the appropriate zinc chromate primer from the paint manufacturer you're going to use, then repaint the entire door frame.
  5. dennismc
    Vancouver BC
    See...someone has not read the proper prep steps...no wonder some paint jobs fail..YMMV
  6. SeaDragon
    SeaDragon New Member
    Kennewick, Wa
    I too have this problem on my '99 404cpmy. Carver used AwlGrip at the time which has been reported to have had issues with peeling and bubbling. I am planning to do a DIY repair and hope for the best.
  7. K1W1
    Are you sure this is the best thing to use on bare Alu?
  8. dsharp
    dsharp Senior Member
    lake jackson, tx
    I would check with a coatings rep. The preferred method used to be an alodine conversion coat followed by an epoxy primer then a top coat. Is it peeling/bubbling around the fasteners or just random? I have not had to paint in about 25 years and I'm sure things have changed.
  9. trmnewt
    trmnewt Member
    Rochester
    It is primarily around fasteners, but some other places, mostly sharp edges/corners
  10. dennismc
    Vancouver BC
    still not correct what has been posted...got Awlgrips site, download the instruction sheets and follow that..geeeeeeeeeeeee........I have been using the stuff on aluminum for over 20yrs..
  11. dsharp
    lake jackson, tx
    I don't have a background in metals but I think is has something to do with dissimilar metals. It creates a white calcium looking material that has to be removed prior to priming. To answer your question, Imrom can be touched up with some degree of success. Henkel makes a conversion coat and should have information on its use. If you sand, prime and paint you should get a respectable job. You can wet sand and buff Imron with #1000 or #1500 if you want it to look "sprayed".
  12. Capt J
    It has been used for years and years on aluminum. Outboard manufacturers use it as a primer on their parts. The best thing to use would be the top coat paint manufacturer that you're going to use primer that is for aluminum.
  13. K1W1
    There must be a reason I have not seen it used on new builds for years.
    I will ask around, my paint guy who was briefly a YF Member sadly passed away so I am looking for someone who can help me with new projects.
    This can be an appraisal question :D
  14. Capt J
    As far as I know, it is not used on entire builds due to cost on that amount of surface area and probably EPA nonsense. BUT, it is still widely used for parts and pieces and smaller scale items such as aluminum door trim, or a O/B lower unit, etc.
  15. dennismc
    Vancouver BC
    The procedure is basically as follows.
    Remove all old coatings down to bare alum.
    Be sure all imperfections or corrosion. is taken out
    Treat with Alum prep as per instruction sheet, rinse etc, dry then apply Alodine 1201, if there are bare patches of alum. that are not taking the alodine, those parts are not "clean" re clean etc . then you can prime coat with appropriate primer depending on what top coats you want to use, then fair out as need, if alum. re exposed after sanding, re clean as first step, re prime, re sand primer as required, wash thoroughly with reducer prior to topcoat, for real fussy jobs you may want to refill any shrinkage spots and re prime those tiny areas.
    Then maybe you can topcoat .
  16. Capt J
    Also, wear a good respirator when sanding the aluminum as aluminum dust is very toxic if you inhale it.
  17. iseau
    iseau New Member
    Red Wing MN
    I have a 466 Carver (probably same paint) I called Carver and they hooked me up with Midwest Industrial Coatings and they mixed up factory paint for a perfect match. I had to by a quart minimum but they also sold it in a spray can format. Not cheap but mix was perfect! As said ealier, the aluminum must be prepped perfect or all will be for not!
  18. trmnewt
    trmnewt Member
    Rochester
    Great tips. Thanks to all!
  19. gbarger
    gbarger New Member
    arkansas
    iseau,
    Do you have a part number/paint code? I need to order some for my 466. Also, who did you contact at Midwest Industrial Coatings? Might make my ordering the paint go easier if I have the part number/paint code.
    Thanks,
    Gary
  20. Monepit
    Monepit Member
    Evansville, in
    I just pulled mine off and had them powder coated. End of problem. Fairly cheep too.
