Click for Westport Click for Cross Click for Glendinning Click for Walker Click for Ocean Alexander
Hull Construction
Discussion in 'Ocean Yacht' started by Chesapeake, Feb 19, 2018.
  1. Chesapeake
    Chesapeake Member
    Maryland
    Hey Ocean Yacht crew...
    Dumb question for you all...
    Hull Construction of a 1995 48SS - Solid or Cored? If Cored, Balsa?
  2. Boomer
    Boomer Senior Member
    Seminole
    Have the same question about a 1984
  3. Chesapeake
    Chesapeake Member
    Maryland
    Boomer - Did you find the answer yet?
    Anyone....?
  4. Boomer
    Seminole
    Wood cored
  5. Boomer
    Seminole
    Wood cored...deposit placed..waiting on surveys
    In the decks. Whats in the wet hull??
    I thought it was solid above the water line.
  7. Trinimax
    Trinimax Senior Member
    I believe they are solid glass below the waterline and cored above
  8. Capt Ralph
    Opps, typed wrong,; I thought it was solid below the water line.
  9. Boomer
    Seminole
    What trinimax said is correct
  10. Tashmoo
    Tashmoo New Member
    Cape Cod
    Boomer sounds like you confirmed wood core on your '84 build.
    Cheasapeake I'm pretty sure that your '95 48SS build would be closed cell PVC foam above the water line, decks and bulkheads. Shouldn't be any balsa on that boat... anywhere. Pop out a bored fitting somewhere to know for sure. Let us know if you confirm one way or another
  11. Navjag
    Navjag New Member
    NC
    How about an '89 or '90 Ocean 48 MY- solid glass below waterline, or cored?
  12. 45SS
    45SS Member
    New Jersey
    Bow pulpit on my 97 is wood cored. I think all else above waterline is foam cored.
  13. Navjag
    Navjag New Member
    NC
    Thanks!
