Click for Burger Click for JetForums Click for Walker Click for YF Listing Service Click for Delta
Help Removing windows on Bertram 25
Discussion in 'Bertram Yacht' started by Quinn Pearson, Aug 26, 2016.
  1. Quinn Pearson
    Quinn Pearson New Member
    Sooke, British Columbia, canada
    just received a 66 Bertram 25 fly bridge. Going to do a total restoration on her. The side windows are cracked so they need removal which I believe I can figure out but tips would be appreciated.
    The real challenge is removing the front windows because they have brown discolouration on the edges and bubbles in the safety glass. I looked at the window opening hinge and thought if I back off the aluminum strip at the top that pins the pivot point of the window that I could slide the window out from under the hinge. I can't get a ratchet with slot head bit on the screw heads because the hardtop is too tight. I have an angle screw driver but it is too big as well.
    Anyone ever pulled the glass on these front windows before?
    The only group that I know of for Ole Bertram support is High Tide Marine.
    They have helped me understand a few Bertram head scratchers..
    http://www.hightidemarine.cc/
