Click for Glendinning Click for Northern Lights Click for Westport Click for JetForums Click for YF Listing Service
Generator issue/Carver 404
Discussion in 'Carver Yacht' started by wolfpuppy, Sep 7, 2010.
  1. wolfpuppy
    wolfpuppy New Member
    Lake Cumberland
    I have a 2000 Carver 404 CMY and would like to pose a question concerning the generator. Is there an automatic switch that flips to AC after the generator runs for a few moments or is there one I have to locate and manually switch? Do I need to open any type of valve for coolant water, or is that automatic? I don't recall the former owner saying anything about these two questions specifically when we were being given the tour prior to purchasing.
    The ginny runs alright, starts and all, but I wasn't getting any AC from it. After a few minutes, I turned it off and decided to figure it out later. I wanted to run the air conditioner while away from the dock, but that didn't happen. Anyone know the answers to these questions? Thanks in advance.
    By the way, if you would like to e-mail me on this, my address is (REMOVED: Read the Rules!) Thanks again.
  2. Pascal
    there should be at least two rotary switches or 2 pairs of dual pole breakers protected by a slide on your electrical panel.
    shoudl be labeled shore / genset.
    to actually connect the genset to feed the panel, you need to swtich the rotary swtich to the Genset position. if the boat doens't have rotaries but breakers with safey slide, turn off the shore side main breaker, slide teh safety slide over and turn on the genset breakers.
    when switching source always turn off the heavier loads like AC, water heater, etc so avoid arcing in the rotaries.
    about cooling, YES there is a sea cock for the genset (and mains) coolign water, it's usually left on. after starting the generator (or mains) always go look at the exhaust and make sure there is plenty of water coming out.
    you really need to become familiar with your boat, a quick tour isnt' enough. I woudl suggest you hire a local captain for a day to review all the stuff you MUST KNOW in order to safely operate the boat.
  3. NYCAP123
    Just to expand on Pascal's reply, you are not able to draw power from shore and the generator at the same time. You have to throw the "Shore" breaker on your main panel to OFF to be able to slide the safety bar iover it which then exposes the "Generator" switch which you flip to ON. Your motors, generator and air conditioning all draw their cooling water from under the boat and expell it overboard. If you follow the intake hoses from those units you'll find a seacock with a valve on it and sometimes a sea strainer. These are often closed during winter layup, but remain open at all other times. The a/c should expell water in a strong flow from the side of the boat. The motors generally through the exhaust. The gen generally also expells through the main exhausts, but sometimes from a seperate exhaust. Start your gen and look for where it exhausts. When no water comes out you won't go far.
  4. tommyfmu
    tommyfmu Member
    Freeport, NY
    Just a quick question while on the subject; on my panel I don't have any gen/shore power slider and have wondered what would happen if my shore power is hooked up and main 1 & 2 on, then turn on my Kohler ; would I get a big 'poof' as the gen electric meets the shore electric ? I've anticipated that there was circuitry built in to avoid shorting, but haven't had the nerve or enough curiousity to have both on at the same time, so always unplug the shore power before running the generator.
  5. NYCAP123
    You would overload the circuits and hopefully blow a breaker. Something is wrong here though unless someone added a gen down the line. If so they must have put in some sort of switch to avoid this scenario. Look for it. If there is none add one. They may have used something akin to a battery switch (1-2, but hopefully no position for both).
  6. Pascal
    yeah, somethign isn't right, i wonder if someone didn't remove the safety slide at some point... VERY dangerous!
    the way the slides work is simple... a small track is screwed on the main breakers. one breaker is hooked up to shore power, the other one to the generator. a small slide the size of one breaker slides left or right preventing both breakers to be lifted on at the same time.
    if you have 2 lines in, as typical with a 120-240/50 shore set up, you have two sets of breakers and safety slides.
    cheaper for builders than using rotary switches
  7. timjet
    timjet Member
    Tampa, FL
    Just a quick question/observation: Do most of you folks leave your thru hulls open when the boat is in the water unattended?
    I always close all of mine (5) when leaving the boat. I figure it exercises the thru hulls so they won't stick, and might prevent a sinking.
    Any reason not to close them? I'm so in the habit of doing this I don't think I'll ever forget to open them.
    Tim
  8. NYCAP123
    Nothing wrong with closing them. Most people don't because it's an extra job each time you use the boat and for fear of forgetting to open one. That could lead to serious damage. BTW, I assume that you leave the one for your a/c open.
  9. Carver370
    Carver370 New Member
    New Buffalo Michigan
    Almost every gas powered Carver I have ever seen including mine has an automatic switch that once the power is disconnected from the boat the gen takes over, assuming its already started. There would be NO switch to manually flip from shore to gen like you guys are talking about.
    Sounds to me like you have a flipped breaker on the actual generator itself. Take a look on the front side of the generator, Im willing to bet that the breaker is tripped.
  10. timjet
    timjet Member
    Tampa, FL
    Not at this time. The temporary slip I'm currently in only has 15amp of shore power and I choose to run the battery charger and refrig. Once at my permanent slip I will use the AC however.
    All of my thru hulls are difficult to get to requiring entry into the engine room. The stbd engine thru hull was impossible to close even when I slithered into the ER. So I fabricated 5 small brackets that I've attached to each thru hull allowing me to open and close them with a boat hook and with out having to enter the ER.
    Carver 370 Wrote: Almost every gas powered Carver I have ever seen including mine has an automatic switch that once the power is disconnected from the boat the gen takes over, assuming its already started.
    That is also true with my diesel powered '98 355 ACMY. Impossible to have 2 sources of AC on an AC bus at the same time.
    Tim
  11. tommyfmu
    tommyfmu Member
    Freeport, NY
    That sounds about right. Once the generator is turned on, I hear an automatic switch behind the AC panel kick on, so must assume that it closes when the gen is off and shore power is on.
  12. Fireman431
    Fireman431 Senior Member
    East central Florida
    Any Carver in that year range will have an automatic switch to detect A/C vs. gennie power.
    If the generator continues to run after starting, then the raw water intake is open. It doesn't open automatically as it is a standard brass ball valve. If water isn't coming in, the genset would shut itself off.
    If you're not getting power from the genset, the first thing I would check would be the white master breaker on the front of the genset control box. That is usually a black box with an on/off switch and a master circuit breaker. If that is on, then check the master breaker on the electrical panel. If that's on, then check the breakers for the A/C unit. Make sure the A/C water pump is on as well. If that's off (at least on my Carver), the A/C will not come on.
