Click for Westport Click for Abeking Click for Perko Click for Ocean Alexander Click for Glendinning
Generator and AC while planing
Discussion in 'Azimut Yacht' started by Deklevc, Jan 10, 2015.
  1. Deklevc
    Deklevc New Member
    Slovenia
  2. Deklevc
    Deklevc New Member
    Slovenia
  3. Pascal
    Of course you can ...
    The only possibly issue with the AC would be if they located the intake too far forward causing it to suck air. If that happen it will shut down without damage
    If anything it s better to run the genset underway as the exhaust back pressure will always force water out of the exhaust system. Ideally the genset water intake should not be a scoop type although so have relief holes on the back side. A few months ago one of our genset ingested water because these holes were clogged with barnacles and I was running on plane running the other genset. Caught it right away, no harm done but I have instructed our diver to check the holes monthly
    Yes, you should have no issues using the generator and a/c on that boat on plane and it's better to use them and to keep the generator loaded when you run it.
