Click for Walker Click for CL Yachts 99X Click for CL Yachts Click for Burger Click for YF Listing Service
Galvanic isolator
Discussion in 'Post Yacht' started by My Affair, Mar 21, 2020.
  1. My Affair
    My Affair Member
    Mystic, CT
    my 1975 42 Post had a galvanic isolator located on the forward bulkhead of the engine room. I cannot locate one on my 1988 46 Post. Did they discontinue using one and does anyone know why?
  2. Davidoc
    Davidoc Senior Member
    Winter:Delray Beach, Fl Summer: Bahamas
    None came on my 91-46. I quickly put one on after I bought the boat. It's been a real asset. Installed it behind the breaker panel with remote indicator.
  3. My Affair
    My Affair Member
    Mystic, CT
    Hi Where did you locate the isolator? Where did you tie in the wiring? Do you have photo available? Thanks
    Any where in the green wire before the shore service outlet.
    Are you sure you do not have one already? Are you sure you need one?
  5. Davidoc
    The other end of the isolator goes to the DC ground for the bonding system. Just key in marine isolaters on google and look for a 50 amp device then pull up the installation instructions and you'll see the wiring diagram it's pretty straight forward and behind the breaker panel is probably the easiest place to find both grounds the AC green wire ground and the DC bonding system ground. I can send you a picture for a week or so not near the boat right now
    I don't think the galvanic isolator is connected to the ships bonding. Just in-line on the ships shore service green (fault current) wire.
  7. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Capt Ralph, It's me! I'm back. Did you miss me? Lol.
    Playing around my bilge last week cleaning with Spray Nine and MANY rags , I noticed both my DC ground and bonding ground where grounded to a stud/bolt on the bocks of my Detroits . From the looks of it, it was clear to me this was original work done by Ocean Yachts at the factory.
    I did not think the bonding should be tied into the motors or DC system?
    What's wit that?
  8. Capt Ralph
    Without DCv isolated alternators, starters and other options, it would be impossible to isolate DCv from the ships bonding system.
    So, Yes; Not to be used for powering options the bonding system and DCv- are tied together.
    It is stray DCv currents that we want to stop between your boat and others thru the water while commonly connected with dock service green wires.
    Usually, the ships green wire (ACv fault current) is not tied to the bonding system while on shore service.
    The O P is talking about a galvanic isolator. This keeps DCv currents from passing thru the shore power service (on the green wire) to commonly connect other boats. Your boat and the boat next door connected by the same green wire can form a path thru the water side of the circuit and lead to galvanic erosion (think wet battery and the boats are the plates).
  9. cleanslate
    Cherry Hill, NJ
    Ok got it, I do seem to have something going on. My zincs seem to getting ''Ett'' up a bit to fast. That being said , I know of one bonding wire that forward that seems to tie in the port and starboard wire run aft that is gone from hanging in the bilge water. I will be fixing that soon while I'm out of the water.
    I will look behind my panel for one of those 1981 vintage isolator. I assume it will be quite large if I have one? 10''x6'' or so?
  10. My Affair
    My Affair Member
    Mystic, CT
    Mine was behind the generator and about 6x8 and was blue in color
  11. chesapeake46
    chesapeake46 Senior Member
    1980 - 46 - no isolator
  12. Capt Ralph
    If it's an old unit, replace it anyway.
  13. postyachts139
    postyachts139 New Member
    ny
    mine is behind electrical panel on 7 43 post
  14. cleanslate
    Cherry Hill, NJ
    I have another question. How about while at anchor/underway when the generator is on should I also have a galvanic isolator on the green wire between the Gen. and the selector switch?
  15. Capt Ralph
    No, You are not sharing the green wire with another boat.
  16. cleanslate
    Cherry Hill, NJ
    I knew that...I was just testing you.:rolleyes:
    Thank You.
  17. Capt J
    I usually install them really close to where the shorepower cord attaches to the boat. Many times you need to add wire, so it's easier to take it off of the boat side where it attaches to the cord or receptacle, run it to one side of the isolator, and then a new wire to attach to the cord end.
