Click for YF Listing Service Click for Westport Click for Cross Click for Westport Click for Glendinning
Fuel tank
Discussion in 'Technical Discussion' started by jeffsc111, Jul 10, 2020.
  1. jeffsc111
    jeffsc111 New Member
    undetermined
    I have a 1995 Mainship 37 fueled by gasoline. The bottom of my 300 gallon gas take has ruptured due to corrosion. Replacing the tank would be extremely expensive. My mechanic thinks that he can epoxy it. Another mechanic said we could install a rubber bladder inside the existing tank. Thoughts?
  2. rtrafford
    rtrafford Senior Member
    Vero Beach
    Are these outboard tanks, under the decks? Is that why they'd be expensive? No, I would not epoxy it. Bladder is an option, but not one that I'd like, either. IF you can get to the tank and remove it as a whole unit, you can replace it without a big expense.
  3. NYCAP123
    No shortcuts with gasoline. Wouldn't trust epoxy long term especially considering how much corrosion may be inside the tank, and a corroded tank could wear against a bladder causing a leak. Result BOOM. You can get tanks made in whatever configuration that works. You could even put in 2 smaller tanks if you need to fit. Get new.
  4. RER
    RER Senior Member
    Newport Beach CA
    Replace the tank or sell the boat at a discount with full disclosure. The options you mentioned are playing with fire. Literally.
    Replace the tank with 2 150 gallon tanks, easier to get in. DON'T patch a gas tank OR put a bladder inside of a bad one.
  6. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    Boom....... Do it right. If there's one rupture, there will be more. No patching. Bladder will chafe through. Use your brain.
  7. SeaLion
    SeaLion Senior Member
    All excellent advice. Tough to accept, but search YouTube for “boat explosion” to understand why.
  8. Pascal
    Epoxy will not work for long. Bladders usually don’t work on marine tanks because tanks have baffles.
    no shortcuts on fuel tanks especially gas boats.
  9. jeffsc111
    undetermined
    Thanks for the suggestions. I’ve had two captains suggest putting in two small tanks and leave the big one alone. We don’t cruise much as we both work and cruising with twin 454 Chevrolet block engines is very expensive.
  10. Capt Ralph
    Our boat, floating office and home was on the Huckins dock for many years.
    Those kids had Carver tank replacements down to a army drill.
    Where I would need to pull exhaust manifolds or remove the whole engine, these kids did save that on most models and removed the wood, panels, trim and options from above the tank and replaced with new. Well, they are great carpenters and finishers.
    BTW, Don't feel pregnant. Carver gas tanks suck.
    If one side is leaking now, it's a bad poker hand your holding till the other tank leaks.
  11. Capt J
    REMOVE the big tank and replace it with 2 equal sized small tanks that equal the size of the tank you removed.
  12. RER
    RER Senior Member
    Newport Beach CA
    Do it the right way. What’s the point to half ass it now if you still have to pay later? The odds are you won’t be able to sell it someday unless you correctly replace the tank or credit the buyer to get it done. But even with a credit I doubt anyone would want to take on the problem. So what are you gaining? Why not have it 100% correct for yourself since you’re going to have to make it correct for the next guy anyway?
  13. Capt Ralph
    Yep...
  14. 993RSR
    993RSR Senior Member
    Annapolis/ Palm Harbor
    There is a company in new jersey that specializes in rebuilding fuel tanks from the inside. They do travel around the Chesapeake as well. They access the tank from the ends or top and cut it open the weld a new bottom into the tank. I have used them on several boats with good results. My experience has been $14,000. on a 400 or so ga tank. Probably businesses like this elsewhere.
  15. SeaLion
    Right! SP Tanks
  16. 993RSR
    SP yea. They did a nice job for us on several occasions where tank access was near zero.
  17. NYCAP123
    $14,000 sounds like a lot to invest in a fuel tank for a 25 y.o. gas boat worth at max $69,000 per Boat Trader and more likely less than $55,000. 37' is right at the cusp where it's hard to sell a gas boat in good condition. It brings to mind a warning I give about the troubles with being a boat's last owner. After investing that $14,000 how long before one or both of those gas engines need a rebuild, and you've basically doubled your investment in a boat worth less than half what you have into it. May be time to cut losses.
  18. 993RSR
    Insurance may help with the repair. Not likely but worth the call.
    If you use and enjoy the boat 14K is well spent. If you are done with it that is another story
  19. chesapeake46
    chesapeake46 Senior Member
    Were they diesel fuel tanks or gas ?
  20. 993RSR
    All of our repairs were bilge mounted diesel tanks. The tech did say they do gas as well just with a few cautionary steps.
