Click for Nordhavn Click for Burger Click for Burger Click for YF Listing Service Click for Northern Lights
Fuel flow data on 4207 with Cat's
Discussion in 'Carver Yacht' started by rholleman, May 20, 2014.
  1. rholleman
    rholleman New Member
    New Iberia, LA
    Just purchased a 1986 Carver 4207 with twin Cat 3116's. Would anyone have real world fuel flow data for this set up? Any other info on the boat such as areas to look out for, tips, tricks etc much appreciated. Current set up has the raw water intake for the engines mounted in front of each engine, which blocks access to the outside of each engine. Has anyone had this set up then moved the strainers to a better location? Pictures? The current strainers are very large, would like to move to a smaller size and relocate.
    Boat is currently in Tampa but will start the trip to Louisiana next week sometimes. 3 boat in this size range, but 1st Carver. Had a Californian then a Gulfstar.
    thank you in advance
    Roy
    "Knot at Work"
    New Iberia, LA
  2. MysticDolphin
    MysticDolphin Member
    Lake Texoma
    cant answer your questions mine has gassers.. but the rest is similiar.. congrates on the buy... i really love my boat...
    Look up ANY fuel flow chart for your HP of 3116's. As long as yours achieve rated speed at WOT, the boat should burn almost the same as the chart at each RPM point. Then just compared that with your speed and make your own chart.......you will be within 5%, probably even closer
