Click for YF Listing Service Click for Burger Click for Abeking Click for Delta Click for Glendinning
Feadship/Van Lent - APRIL FOOL
Discussion in 'Feadship Yacht' started by Yacht News, May 29, 2006.
    This is the new Feadship... has a double mast arangement i guess a bit similar to Double Haven. She carries an open air tender just behind the Bridge on the Port side. She seemed to have been launched on the 23rd of this month from the shed. Most people probably remember her under the code name *Lioness*
    She is around 61 meters i think and is all white with black tinted windows.
    Just received images from Feadship on April Fool. A full press release will follow...
    Specs:
    Builder: Feadship – Royal Van Lent shipyard
    Design: De Voogt Naval Architects
    Naval Architect: De Voogt Naval Architects
    Type: Twin screw motor yacht, steel hull and aluminium superstructure
    Length overall: 60.96 m / 200’0”
    Beam max: 10.90 m / 35’9”
    Draft (loaded): 3.3 m / 10'8"
    Fuel capacity: 125,700 / 33,210 US Gall
    Fresh water capacity: 29,600 / 7,820 US Gall
    Water makers: HEM Duplex30/4000
    Propulsion:
    Main engines: 2x Caterpillar 3516B-DITA, 2x 1492kW @ 1600 rpm
    Propellers: LIPS/Wartsila propulsion
    Propeller shaft: Rubber design
    Reduction gears: ZF W7540
    Stabilizers: VTNaiad Marine
    Performance:
    Max. speed: 16 knots
    Range: (@ 13 knots): 5,000 NM
    Classification: Lloyd’s @100 A1, SSC, Yacht (P), Mono, G6, LMC, UMS, MCA
    Thanks for the statistics Carl. She is very pretty indeed....i guess my description of her was not bad at all:p :)
  4. Yacht News
