Click for Abeking Click for Northern Lights Click for Westport Click for Burger Click for Perko
Diesel furnace
Discussion in 'Carver Yacht' started by hopper5, Feb 3, 2013.
  1. hopper5
    hopper5 Member
    Olympia,wa
    Easy question : How much should a diesel furnace smoke when first starting ?? When I use mine on my 1994 440 it bellows quite a bit of black smoke for about 45 seconds then is clean.........NORMAL ?? I recently replace filters .....Thanks
  2. RT46
    RT46 Senior Member
    I think that 45 seconds of black smoke on start up of a diesel furnace is too much.
    I would change filter, nozzle, clean burner, inspect flu, and adjust air intake as appropriate.
    I puff of smoke when they first light off is ok,
    call the customer service to confirm.
  3. CR CRUISER
    CR CRUISER Member
    Campbell River, BC
    If it's an Espar, then it probably needs a new combustion screen. It's a very fine mesh tubular screen around the glow plug. The symptoms are smoke at start-up and reduced heat output.
