Click for Walker Click for Ocean Alexander Click for Ocean Alexander Click for CL Yachts 99X Click for Westport
Cat c32a. Coolant leaking out of the air filter.
Discussion in 'Engines' started by Hatt54, Oct 5, 2019.
  1. Hatt54
    Hatt54 New Member
    Falmouth
    Has anyone seen or heard about coolant leaking out of an air filter on C32 A Cats ?
    Coolant or air filter oil?
  3. Hatt54
    Hatt54 New Member
    Falmouth
    It looks like coolant. The marina cleaned the air filters. Have not had a chance to ask what they used. Have you heard of coolant coming out of the air filters because i have not.
  4. Pascal
    Coolant? I don’t see how that’s possible. The air filters are supposed to be cleaned and lubricated with a special oil.
    “The Marina cleaned the air filter”. Unless they are Cat specialist that’s a red flag: I would NEVER let marina employees near A pair of C32s.
  5. cnvsback
    cnvsback Member
    Perhaps it is the air filter oil normally dyed red, that you are mistaken for "coolant"?
    Normally a product is used to clean the filter, then once dry the oil applied.
    You may think it's coolant because of it's red/pink color.
    By design, The Air-Sep system the C-32 use would not let any thing come out of the turbo.
    If the marina cleaned the filters and now you see this, It is new filter oil draining from the filter media.
    This oil is a special additive and a part of filter cleaning.
    Couple of good hours of running under load should clean up any excess oil. Slow speed operation won't draw enough air, to clear the filter media of the oil.
    I used to managed a Hatt with C-32s. Filters were serviced just before my owner purchased the boat. Same problem.
    New owner never ran over a warm idle and months later, the filters were still leaking red media oil.
  7. Hatt54
    Hatt54 New Member
    Falmouth
    I did not think coolant could leak out of the air filter. The marina has a mechanic that is the person who cleans them. Is it a big deal if the filter oil leaks out of them?
  8. Capt Ralph
    If it's the K&N red media oil as we are sure it is, not at all, it's just messy.
  9. Hatt54
    Hatt54 New Member
    Falmouth
    Ok thank you. For your help
  10. Beau
    Beau Senior Member
    Beaufort, NC
    Woud it be normal to use so much oil on the filters that it would drain like that? My Air seps have never emitted a drip of filter oil....
  11. Capt Ralph
    It just takes a few drops of oil to service the filter media. Those that don't know, just can not understand; you need not use all the oil in the K&N kits.
    I'd say the kit comes with enough oil to service the filter 3 times. So I keep the extra and use Scrubbing Bubbles or any mild foaming cleaner, rinse, dry overnight and use the left over oil next time.
    This reminds me, Time to clean & service mine. Stuff buried in the warehouse,, somewhere..
  12. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Yup, got my K & N stuff at the local automotive store. I can not remeber if the cleaner or the oil comes in a spray bottle...if at all. But I have the red oil in a spray bottle and lightly spray the Air Seps filter. As CR said you don't need a lot of oil, nor should you use the entire bottle.
