Click for Abeking Click for Westport Click for Cross Click for YF Listing Service Click for Burger
Cat 3126Bs, Volvo 480s or 450 Cummins in a 03 Pursuit 38
Discussion in 'Engines' started by craigsduc, Jun 16, 2011.
  1. craigsduc
    craigsduc New Member
    Thousand Oaks
    I,m pursuing a 38 ft Pursuit ( hey...thats weird ) w/tower as a " newer/smaller" alternative to a 1981 Hatteras 55 SF with 1271s I looked at in St Pete last month. The 55 was beautiful but many warned of the cost to own and recommended the smaller/newer option. I know as well it is smarter for us to go this way and have found two sister boats. One blue hulled boat in Key Largo ( Ocean Reef ) with 1400hr 3126Bs and the other white hulled boat with 1800hr Volvo 480s in Destin. Have had some comments from pros regarding the Cats as not being the most popular engine Cat ever made but in these 38 Pursuits, it seems to be the only engine Cat used. The mechanical Volvo 480s are the Volvo package at the time and a few boats have Cummins power. Cost of ownership is a major concern and have heard of a few engine related "Catastrophes" lately but dont seem to hear much about Volvos or Cummins. One seal failed in a 3126B I just looked at here in S California and required a new/rebuilt head @ $11K ( which was covered by the owners insurance as the Cats were out of warranty ). The other was a 3406E that wasnt running right and ended up having a hole in the block and now needs a complete replacement @ $46,000. I know these are boats but I begin to wonder if Cats are not what I have always felt to be the right choice. I also know certain model engines are better than others and all require proper maintenance and use to live a long life.
    Opinions? Should I opt for the Volvos or look at the Cummins powered boats??
  2. K1W1
    You should think of the failures you hear about objectively.
    How many CATS fail compared to how many are out there doing their job
    How many Volvo's fail.....
    How many Cummins ......
    How many Yan.......
    When you say a 3406 wasn't running right and ended up with a hole in the block I would hazard a guess that it indicated a problem before it actually fell apart.
    Regardless of the brand, When an engine is trying to tell you it is ill, take note, ignoring it might well prove a lot costlier and troublesome than taking care of it properly.
    Did you ever find out what actually caused it to fall apart?
  3. craigsduc
    Thousand Oaks
    No as it was in a boat I looked at when I was in Fla recently. It was a 01 48ft SF with about 1500hrs owned by someone that did not appear to abuse boats but cannot state how the maintenance was handled. Like you said, there is always a story behind the story. Did not hear engines when I looked at the boat which were sick when I saw it obviously. Some engines obviously are better than others and there are some models that are better than others within a manufacturers line up. I have preferred Cats but in the boats we were looking at, the majority had Detroits. I learned to stay clear of 92 series engines which seemed to be a commonly agreed to suggestion. Now with smaller/newer being the new course, it has opened up the newer engines which has now prompted me to ask for suggestions again. I actually am now looking at a 03 Tiara 44 Sovran with C12s @ 600 hrs here in S Cal which we might be able to buy for the mid/upper 200s. My concern with that one is the owner is not a boater at all and wants nothing to do with boats again. Makes me a bit concerned with who is maintaing the boat. Bad maintenance can cause even modern C12s to have issues too so I am really going to have them looked at closely if we pursue the boat.
    Ask him for records, or call the local CAT dealer with the serial number. It is possible a non-dealer cat certified mechanic has done the work also and it won't show up in the CAT system. Just because he is a non-boater, doesn't mean the maintanence was not done. I would definately consider the Tiara.
    I have a customer with 3126 B's, the 450hp ones I believe.......they have been great motors for him, I ran the boat from Ft. Laud to St. Croix when it had 1000 hours, it now has 2500 hours on them and he has not replaced ANY major components on them.
    Volvo makes a good motor, however I'd stay away from them. Most parts are not usually in stock and take a day or two to get in......Even stuff like an oil filter or fuel filters here in fort lauderdale. Parts are also twice what they cost for a CAT. Cummins are good too, however they're pretty proud of their parts prices also.
