Click for Cross Click for Westport Click for Perko Click for Northern Lights Click for Burger
Carver 350 aft cabin , Gaskets Windows
Discussion in 'Carver Yacht' started by greenat, Oct 8, 2014.
  1. greenat
    greenat New Member
    Austria
    Good Morning!
    I have 93` 350 aft cabin carver
    Can you help me? I have a problem. I need gaskets for the boat for the two Windows (aft cabin, front cabin)?
    And Water comes in the aft cabin on the corner of the bed?
    Also Water comes in the kitchen?
    Have anyone the same problems?
    Its possible to became gaskets for the sallon windows?
    thanks for help
  2. Glenn D
    Glenn D New Member
    San Diego, Ca
    I have just replaced the window weather strips on my 93' 350. I total removed the window frames from the boat and had them powder coated for both windows $250.00. I did find the windows can out pretty easily due the caulking was basically shot. I purchased new weather stripping from Taylormade the manufacture of the windows. It's pricey though $940.00 to replace all the weather stripping including the salon windows. It was well worth it my windows glide open and close with ease now. My aft cabin port side corner also leaks and can't seem to track it down, I do think it's the strut on deck above and just tried rechaulking the base again. Good luck
  3. trmnewt
    trmnewt Member
    Rochester
    I had the same problem, and it was traced to clogged drain holes in the tracks for the windows (it was a '96 though....)
  4. Glenn D
    Glenn D New Member
    San Diego, Ca
    Thanks for your comment most appreciated..
  5. tommyfmu
    tommyfmu Member
    Freeport, NY
    Not sure if I'm understanding the question right or not, but we were getting leaking from our aft cabin windows, mostly from rain. We simply sealed the outside perimeter with 3M 5200 and haven't had a problem since.
  6. greenat
    greenat New Member
    Austria
    Hy Glynn
    can you give me the Part number of all Gaskets.
    or could i Write a Email with Type of boat to taylormade
    have you contact data from taylormade
    Tanks
  7. NYCAP123
    If you SEARCH under Carver Windows or Window Leaks you'll find a several threads on the situation.
  8. Barefootin
    Barefootin New Member
    long island NY
    can you help with how windows are removed ?
  9. Glenn D
    Glenn D New Member
    San Diego, Ca
    First you need to remove the sliding window section. Unscrew the the screws with acorn nuts on the vertical aluminum and lift up then out this gives more room to remove the Windows. Then remove the both window sections. Remove the perimeter screws around the exterior of frame. Put two inch wide of tape on the gel coat around the window and then with a thin blade putty knife start breaking the chalking seal around the frame. Pull on the frame and break it free it takes a little work but use some muscle. When you reinstall use 3M 4200 to rebed use a 1/16/1/8" shim in some areas around the frame so all the 4200 is not squeezed out. After that's cleaned up and dry put a small head of 4200 around the perimeter and your done.
    Glenn
