Click for Burger Click for Northern Lights Click for Westport Click for Delta Click for Abeking
C32 Aftercooler Maintenance
Discussion in 'Engines' started by SOS, Dec 11, 2010.
  1. SOS
    SOS New Member
    El Gouna Red Sea Egypt
    Hi I have 1730 hours (alot of trawlling causing these hours)on my C32s model 2005, how often should I maintain my after coolers, what is the sign they need maintenance?
    Look in your maintanence schedule. But they should be cleaned every 1000 hours, as well as heat exchangers, valves adjusted, injectors checked, I believe according to cat, but look it up.
  3. captbluewater
    captbluewater New Member
    Los Suenos
    That is correct and if you do not put 100hrs in 2 years it needs to be done every 2yrs. I just did mine and only put 400hrs in a 2 yr period and the after cooler was half clogged with corrosion.
  4. SOS
    SOS New Member
    Thanks for your reply, will work on it however my CAT dealer is saying its ok and does not want to take it out, is there a way to check the status without dissasembling it?
  5. SOS
    SOS New Member
    In other words, did you feel a difference in the perfomance before and after the maintenance procedure? thanks.
  6. Swamp fox
    Swamp fox Member
    NC
    You might notice the engines running a bit hotter than usual. I have 3412s and can verify the top of the aftercooler condition just by un-bolting the cover. Heavy, but not as bad as lifting out the aftercooler from the manifold. If the fins are thick with oil and gummy, time to get them cleaned.
  7. CatTech
    CatTech New Member
    south FL
    The aftercoolers are due every 1000 hours along with the other coolers, heat exchangers and turbo's as well as valve adjustment and injector test/ adjustement. A visual inspection of the after coolers can be done by removing the compressor housing from the turbos and looking at the top of the aftercooler. Excessive oily residue in the compressor housing, face of the turbo or on the top of the aftercooler needs to be addressed. A raw water cooled aftercooler also needs more attention paid to the water side than a jacket water cooled system. Any water leaks from an aftercooler can cause major engine damage. Signs of a excessively clogged aftercooler on the air side are increased smoke from the exhaust, higher air inlet temperatures, loss of engine power.
  8. SOS
    SOS New Member
    Thanks for your feedback, i have checked the air side of the AC with an Infra Red Scope and it appeared to be clean no oil residue, i did not check the water side yet, the engines run clean with no smoke at all aside from white water vapour, however i'm missing almost 200 rpms, i have stbd engine relatively higher in temp only at top speed 2100 rpms but managed to find out why due to restriction on the raw water intake net which i have addresses and due for a sea trial to check if it runs normally again.
    I still need to check the loss of RPMs after i address the overheating issue, i'll run a No Load test and see where i reach then move forward.
  9. CatTech
    CatTech New Member
    south FL
    the water side will not effect performance and your loss of rpm. You should get 2410 RPM no load if your control system is requesting 100 % throttle. 200 rpm loss is quite substantial the most common cause is a dirty bottom, running gear, or added weight to the vessel. Based on your other post you have MPD displays which will show any sensor/ injector fault that would be causing a loss of RPM. before the sea trial replace all fuel filters and clean the air filters to rule out any chance of those being a problem. A full performance sea trial should be performed to determine the cause of the RPM loss.
  10. SOS
    SOS New Member
    Thanks for your reply, i have already replaced primary and secondary fuel filters, cleaned the running gear with sand paper, however i have been floating for almost 20 months yet my bottom is clean i use the boat frequently, i have added a Davit that weighs 400 Lbs (not much i beleive) can be easily compensanted with fuel right? can there be problem with the controls? Our fuel in this part of the world is not the cleanest though, Air filter the indicator on the filters is showing clean filter, what do you think. Shall i force my CAT dealer to take off the after cooler and clean them?
  11. CatTech
    CatTech New Member
    south FL
    I dont see why you would have to force them to remove the aftercoolers for cleaning it is a maintenance item and you will be paying for it. I am guessing you are out of warranty anyway unless you have an extended warranty. Iehter way I think a better use of your time/ money would be a performance sea trial done by the local CAT dealer to determine the cause of the RPM loss instead of guessing or troubleshooting this yourself.
  12. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    We are just about to use a new product that we got in last week. It may be perfect for this sort of thing.
    Anyone used it yet?
    http://www.rydlymemarine.com/
    In the old days we used to use muriatic acid dilate in a big drum. Not very 'green' but it worked.
  13. SOS
    SOS New Member
    Thanks for your prompt reply, i'm truly out of my extended warranty that ended in January 2010, i have the local CAT dealer fully aligned with me but the problem they did not even address the RPM loss although i have a maintence contract with them and they come over to change oil twice per annum and sea trial the boat each time, I will have them perform the Sea Trial next time i'm at the boat and see how it performs, many thanks for your valuable advise and input.
  14. CatTech
    CatTech New Member
    south FL
    I have seen companies that use this or a similar product to clean the raw water side of the cooler/heatexchanger with much success. But it does not clean the air side of the aftercooler nor the coolant side of the heat exchangers. Even more important is the pressure testing of the after cooler to be sure there are no leaks of water into the engine.
  15. Fishtigua
    Guernsey/Antigua
    Quick question.
    Do you know if the OP has been using CAT's Extended Life Coolant? This should keep any performance loss to a minimum.
    What do you think about this product? Volvo have just launched their own one too.
  16. SOS
    SOS New Member
    Thanks for your feedback, i have been using CAT extended life coolant, i'm runing a sample analysis to check its current condition, as i did not change it before and not sure the previuos owner did, its should be more than 5 years old now, will repalce it anyways to eliminate any possible effects.
  17. CatTech
    CatTech New Member
    south FL
    ELC is a very good product it has a life of 6 years with regular sample analysis and an extender added at 3 years. ELC provides better metal corrosion protection than regular coolant. Any engine that has had regular coolant in it must be flushed thoroughly before refilling with ELC. I have also noted that it will expose leaks that were not there with regular coolant. Not sure why maybe someone else can explain this.
  18. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    My guess is it's not the ELC that exposes the leaks, it's the results of the "thorough" cleaning before the change over.
  19. Fishtigua
    Guernsey/Antigua
    Bill,
    I think C32 ACERTs come filled with ELC from new by all boatbuilders. Most dealers tend to change it after the hours and how the boat is used, rather than just the year. If you spend hours just trolling, I would change it quite often, extender treatment or not.
    On the commercial fishing boats we used to change the oil every two weeks and the coolant about every 6 months but those suckers were running non-stop for weeks on end.
  20. Capt J
    I have heard from the local CAT dealer to never use it in C18's, for some reason some of them don't cool properly with it.
    I have heard from other CAT certified mechanics not to use the extended life as when you get to about the 2 year mark the PH gets very acidic in it and it leaves a lot of scale in the coolant passages.
    Take it for what it's worth.
