Click for YF Listing Service Click for YF Listing Service Click for Northern Lights Click for Abeking Click for Walker
Bottom Paint Suggestions?
Discussion in 'Technical Discussion' started by DuoProp, Jan 15, 2004.
  1. DuoProp
    DuoProp New Member
    Miami, Florida
    We're getting ready to pull the boat out of the water for a bottom job. Has anybody seen anything new in the market that lasts longer than the usual suspects in anti-fouling paints? In searching the net, I came across Blue Water paints, that received the 2003 NMMA Innovation of the year award. Are any yacht forums members familiar with it?
  2. trouty
    trouty New Member
    West Australia
    Getting the right one
    Is half the battle Duoporop.
    It all depends on a lot of factors.
    Like water temp and the amount of use your boat gets as well as how fast your boat goes.
    For 4example - you might ask a pro fisher what he uses and select that - and it MIGHT be a mistake.
    Why?
    Wel he may use his boat every day - and possibly at speeds twice your cruise, say 40 knots (if its a large modern vessel)..
    That fellow would choose a hard, high build, high speed, abalative, self polishing co-polymer antifoul.
    Why?
    Well he travels fast so the paint needs to be hard to stand up to the abraisive force of the water. It needs to be high build (lots of coats/thick) to not wear away before the fishing season is over.
    Now you ask him what he uses, and apply that to a slow 20 knot hull thats gets used 4 times a year - you don't go fast enough to wear any of the hard paint away hence the weed growth stays attached, you use it so seldom that the weed really grows like 10 bastards on the bottom of your hull, and then likely you claim it to be a dud antifoul paint.
    Truth is you probably should have selected a soft, slow speed, low build, ablative self polishing co-polymer antifoul paint for your craft.
    It's all about getting one suited to your vessel/usuage chartacteristics.
    Good luck!
  3. brianwill
    brianwill New Member
    Texas
  4. LMBoat
    LMBoat New Member
    Ft Lauderdale
    I have used Trinidad here in SoFL with good results. Prep is key, and be sure to do the underwater metal (running gear, trim tabs, through hulls, etc.)
