Click for Burger Click for Perko Click for YF Listing Service Click for YF Listing Service Click for Ocean Alexander
Bennett trim tab indicator issue
Discussion in 'Carver Yacht' started by rholleman, Aug 9, 2014.
  1. rholleman
    rholleman New Member
    New Iberia, LA
    Have Bennett trim tabs on a 1986 Carver 4207. Had the boat hauled and trim tabs were removed and rebed but now the indicators run up and down constantly. The trim tabs work correctly, just that the indicators will run from full up to full down constantly. I would assume it is a recalibration issue but cannot find any documentation on the boat about the trim tabs and looking on Bennett's web site don't find any product support for the old (86') indicators or system.
    Any suggestions to fix indicators appreciated,
    Roy
    Knot at Work
    Orange Beach AL (currently)
  2. NEO56
    NEO56 Member
    Miami
    Afraid I can't be much help Roy, but back in the day when we raced ski class boats with Mercury twisters, the engine was your trim tab. We came up with a push pull cable and cut a vertical slot in the dash, that would indicate trim level so we didn't have to keep turning around for visual conformation. It was crude but it worked. I honestly don't know how you adapt that to trim tabs. I'm sure someone here knows exactly how to fix your problem...good luck.
  3. g36
    g36 Member
    chattanooga
    it would be good if you knew what model of indicator you have since bennetts been around for a long time. i googled the link below and it does provide some cal instructions but dont know if this is the model you have if it doesnt help i would just contact bennett and see if they can help troubleshoot over the phone
    http://www.bennetttrimtabs.com/pdf/instIcon/TPI_installation_instructions.pdf
  4. rholleman
    New Iberia, LA
    Thanks. I am at home, about 6 hrs away from the boat for a couple weeks but will find what model I have when I return to the boat. It appears to be original equip (circa 1986), as I have not been able to find any indicators that look like what I have.
    Contacting Bennett may just be the best option. Thanks for sending the link for instructions. Those look a little newer than what I have but most likely the same procedure.
    It sounds like the indicators are either not attached or not plugged in.
