Click for Abeking Click for Walker Click for Abeking Click for Perko Click for Delta
Any 50' Posts for sale? [Found]
Discussion in 'Post Yacht' started by Quality Time, Jan 20, 2023.
  1. mapism
    mapism Senior Member
    Sardinia
    As much as I appreciate CR experience and competence, I actually think his guess (he did say "I wonder...", in fact) is not correct in this case.
    To my knowledge, MAN always measured engine power according to DIN standard, which is at the flywheel but with all engine accessories installed (and within certain temperature limits for fuel/air/raw cooling water, but that's irrelevant in this context).
    I never came across official MAN tables or drawings reporting 860hp for their D2840LE401 engine, or other different power numbers related to any of their engines aside from the DIN ones of their spec sheets that I previously attached, for that matter.
    But if you are aware of something like that, I'd be curious to see it.
    BTW, even if usually each engine model is often mated to a particular gearbox model, boatbuilders ultimately chose whatever they prefer, as long as it fits the flywheel housing size - i.e. SAE 1, in most MANs.
    Over here in the U.S. during the 2000s, the U.S. builders (mostly Sportfish) jumped back and forth between CAT and MAN with whoever every year or two with had the best HP to weight ratio and newest design, best computer controls, engine controls and displays. It went from CAT in late 90's with the 3406's, 3126's, and 3196's, 3412's but then some of those had a lot of aftercooler and other issues. So they jumped to the MAN 1050s (which pretty much fit where a 3406 did) and 820's in the early 2000s, but then the 1050's had a lot of issues early on, then back over to CAT for the C18's and C30's, then a mix between MAN and CATS mid to late 2000s once MAN got into the common rails.
  3. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Was looking at Yachworld the other day. Saw a 50’ that looked nice , at a reduced price due to mechanical problems .
    Depends on what and who you know, could be a boat for you. Probably a highly negotiable boat…?
  4. Quality Time
    Quality Time Member
    Upper Chesapeake Bay
    Thanks, I do see that one now. Not really a project I'm looking to take on being so far away.
    We've got a lead on something and are going to see it in a few weeks.
  5. boatpoor
    boatpoor Active Member
    "Post Op"is back on the market. Now named "Patriot" Denison has it listed.
  6. Reel Antsy
    Reel Antsy New Member
    Solomons Island, MD
  7. Quality Time
    Quality Time Member
    Just wanted to close this thread out by saying that we purchased and brought home a 2006 50' Post (hull #98) last week. The boat ran great on the three day trip from Charleston to the Upper Chesapeake Bay.
    Treads, Greg Page, mfan46 and 4 others like this.
