Click for Nordhavn Click for Perko Click for YF Listing Service Click for Burger Click for Walker
Air conditioner condensation? 50 Post
Discussion in 'Post Yacht' started by rjsc5, Jul 23, 2017.
  1. rjsc5
    rjsc5 New Member
    Chesapeake Bay
    On a 1996 50 Post, does the AC condensation drain overboard or into the bilge?
    Thanks in advance for your replies.
  2. baltimore bob
    baltimore bob Member
    Baltimore, Maryland
    In my ancient Post, the condensate drain is teed into the AC water outlet. Apparently a venturi effect carries the condensate overboard with the condenser cooling water.
  3. strike 3
    strike 3 New Member
    georgetown md.
    On my 1998 50 post the ac drains into shower pump
  4. sigarn
    sigarn Member
    Wilmington NC
    I would bet it drains into the shower sump. Thats were all my units drain into on my 53. I highly doubt it would just drain into the bilge.
  5. rjsc5
    rjsc5 New Member
    Chesapeake Bay
    Thank you for your help.
  6. sigarn
    sigarn Member
    Wilmington NC
    Im not sure where the sump is on a 96 - 50, but the lines are normally 1/2" and they come into the top of the sump lid on many models.
  7. AltonAimar
    AltonAimar New Member
    Savannah, Ga
    1986 46' air handler in cabinet forward of the Salon dinette, under the Bow Bench seat. Can anyone tell me where the condensate drain is located? Lots if cindensate running into upper bunk in guest S/R.
    Try to follow the hose. You could try blowing the drain out with water or air. At that age it is also highly possible the drain hose is split somewhere.
  9. mwwhit1
    mwwhit1 Senior Member
    a
    I have an 84 43. I think our Salon AC setup is very similar. Mine has clogged before coming into the upper bunk. Mine has a small access panel over the upper bunk. About 6-8 screws and it comes out. I have a white hose, with a Tee that connects the AC condenser for the side stateroom. Disconnect the hose from the T and blow into the hose going up to the salon drain. Should see junk and a bunch of water come back out. Hope this helps.
  10. prestonannaj
    prestonannaj Guest
    My post 46’ 1986 salon a/c condensation drain hose runs down the starboard side to the drain pipe that run down that side. It will get clogged where the hose meets the pvc pipe that runs down the side to the aft.
