Click for Glendinning Click for Abeking Click for Ocean Alexander Click for Northern Lights Click for Cross
Admiral 65M
Discussion in 'Unique, Custom or New Yachts' started by Yacht News, Sep 22, 2007.
    It is said to be the flagship of the Admiral CNL line. It is also said to be a perfect combination between Luca Dini and AMY Naval excellence. This fusion led to a pleasing and powerful looking design that is the Admiral 65M.
    Starting with a steel hull and aluminum superstructure, the 65M motoryacht sprawls nearly 43 feet wide offering not only a sumptous and large master suite but larger room overall. This project is envisioned to carry 12 privileged guests at a time.
    The Admiral's interior and exterior spaces are designed to be distrubuted over the five levels. While these spaces are scattered far and wide within the 65M length, the yacht does not give the sense of overkill so to speak. All spaces are designed to be close to each other and not far away to cause an alienation between spaces.
    The design features extensive use of glass which will bring the outside into the inside thus offering beautiful vistas while indoors. The design displays a number of hydraulically operated folddown platforms which can serve as private spaces to the sea. These features have been successfully incorporated on many other large yachts in the past.
    On paper, the Admiral 65M is set to achieve a speed of 18 knots utilizing azipod propulsion. Two Caterpillar 3516B diesel generators will supply power to the two 1800 KW azipods. The yacht is set to have an extended range of well over 5,000 NM.
    Some statistics on the Admiral 65M design:
    LOA: 65 m 213.3 ft
    Max beam: 13.2 m 43.3 ft
    Max height: 3.7 m 12.1 ft
    Max draft: 3.7 m 12.1 ft
    Displacement: 1500 t 0 lb
    Fuel capacity: 190000 l 50193 gls
    Fresh water capacity: 55000 l 14530 gls
    Main engines: 2 x AZIPOD Diesel/electric
    Max power: 2 x 1250 Kw Generators: 2 x CAT 3512B - 2 x CAT 3408C
    Top speed: 15 Knots Crusing speed: 12 Knots
    Range@crusing speed: 5500 Nm
    Crew places: 11 + capitain's cabin Guests places: 12 + owner's cabin
    For more information on the Admiral 65M project travel here:
    http://www.cnl.it/
