Click for Nordhavn Click for Abeking Click for Ocean Alexander Click for Westport Click for JetForums
Adjusting Control Detent strength?
Discussion in 'Post Yacht' started by PtJudeRI, Jul 15, 2015.
  1. PtJudeRI
    PtJudeRI Senior Member
    Pt. Judith, RI
    Hi guys, anyone here work on this at all?
    My boat ( 2002 50') has the sport pod helm with single lever Glendinning controls. The unit is an EEC-1000 and has both electronic and manual cables. The detent is very strong getting in and out of Neutral, and I find myself really jerking it in and out of neutral, many times revving the engine more so than I would like when docking.
    Has anyone adjusted their detent strength, is it possible?
  2. Kafue
    Kafue Senior Member
    Gold Coast Australia
    On the older Glendinning controls, there is a screw located in the front of the unit that will increase/decrease the indent. The unit (primary unit) is located nearest the gearbox, usually on the port gear. Check the manual if you have one. It is a relatively easy adjustment. The fact that yours is very strong may mean there is a cable issue, again, not a big problem to find and fix.
