Click for Burger Click for YF Listing Service Click for Glendinning Click for Westport Click for JetForums
Adding a winch eye
Discussion in 'Chris Craft Connies, Commanders & Catalinas' started by joe marshall, Dec 29, 2021.
  1. joe marshall
    joe marshall New Member
    Fl
    I have a 84 catalina 280 how hard would it be to add a winch eye to it
  2. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    I"m not particularly familiar with the vessel, but for a fiberglass boat it shouldn't be too difficult. I suspect that Catalina has a very thick hull though.
  3. Capt Ralph
    I think you are talking about a trailering winch eye but not sure.
    Please expand or define winch eye. Where do you want to install it?
  4. joe marshall
    Fl
    Yes to trailer the boat
  5. Capt Ralph
    If you know where you want the U shaped eye bolt. You need to get to the back of it. I have done upgrades where the U bolt has near and pulled out of the hull.
    I use a heavy gauge pipe and float it in with high density epoxy. Float the 2 foot pipe rite in the stems V. The epoxy will be thicker than cold peanut butter.
    2 plus days later, drill in your U bolt holes. Do not skimp on the threaded length , diameter or cost of the U bolt.
    Seal it in with 4200 and go.
    Our work boats needed a strong point to pull backwards on. I used to set 2 U bolts in the stems, this way and it pulled hard well.
    One at water line with a 20' x 1" hawser spliced around the U bolt with a heavy thimble.
    Another reachable for a second line if needed.
    Deck cleats were never strong enough & exposed to the crew/operator/customer (not safe) if anything came loose on either end.
    If you are going to try and winch that fat Carver up on a trailer, Do above with a fresh dual ( no cheap **** here either ) compound rig and stand back.
    If you are not competent to prep and drag a hulk up a trailer, please consult a pro. People have lost body parts and more, trying to move heavy objects.
    Your needed equipment will not come from Harbor Fright as a hint.
