Click for Nordhavn Click for Cross Click for YF Listing Service Click for Delta Click for YF Listing Service
A/C unit locations Carver 4207
Discussion in 'Carver Yacht' started by rholleman, May 6, 2014.
  1. rholleman
    rholleman New Member
    New Iberia, LA
    On a 86' era Carver 4207 where are the a/c units supposed to be located?
    Thank you in advance
    Roy
    Look for the a/c return grates. The units are usually really close to them (behind them).
  3. MysticDolphin
    MysticDolphin Member
    Lake Texoma
    one is under the forward berth, one is in the wall on the port side of the salon, take off the return vent to see it.. dont know if you have a lower helm.. and one is on the starboard side of the aft cabin in the closet at the floor...
  4. Rene Dupuis
    Rene Dupuis New Member
    Mystic Ct
    Hi I am looking to buy a 42 Carver aft cabin, 1988-90, for the Great loop.
    I have a question about the AC. Are the 3 units big enough to cool the boat in the summer heat of the southeast US?
    It solely depends on their size and location, but they shouldn't have an issue. Now if you're looking to keep it in the 60's and it's 90F outside, most yachts would have a problem keeping it that cold. But in the 70's should not be a problem in South Florida with 3 units on that size boat generally. I manage a 37' Silverton MY that has a lot of interior cubic footage and it has 2 units and they do fine.
  6. Jeff D
    Jeff D New Member
    Ft. Monroe, Va
    I am currently on the Loop and have a 1990 Carver Californian 45 with three AC units. I have only run all three units at the same time a few times. Normally, I only use the salon unit to cool the interior sufficiently before sleeping. If you have had a long run or an exceptionally hot day, run the bilge blowers for 15-20 minutes to pull some of the heat off the engine compartment. This will help, but the engines will be a significant source of heat, a feature you will appreciate if you go up to Georgian Bay or in the winter time in Florida.
  7. Jerry w
    Jerry w New Member
    Fort Worth, TX
    I have a 4207 here in Texas. My 3 units keep it nice during our HOT summers. I agree with running your engine room blowers to get rid of some of the heat from the engines.
