Click for YF Listing Service Click for Northern Lights Click for Burger Click for Nordhavn Click for Walker
8v92 TA Tech specs
Discussion in 'Engines' started by ArielM, Jul 25, 2011.
  1. ArielM
    ArielM Senior Member
    Los Angeles
    Does anyone have the torque specification on an 8v92 ta? I know it has 720hp but i dont know how much torque it has. Any info is appreciated.
  2. K1W1
    I would suggest a bit of time spent on Google.com will probably be the best place to start. There is a plethora of info on 8V92TA's it just needs time to sift through and find one with your specs.
    You might also be able to rough it out by what the max Torque your gearbox can accept is.
  3. Yachtjocky
    Yachtjocky Senior Member
    I would ask CaptJ, ;)
    1250lbs at 1200 rpms is the maximum torque produced by a 8v92TA
  5. Jimbo1959
    Jimbo1959 Member
    Stockton, CA
    The 1250 lbs ft of torque you are referring to is for the on highway class 8 application. I would suggest Ariel's 720 hp twin turbo models with after coolers, inter coolers and 140mm injectors is substantially more. Somewhere around 1550 lbs ft torque.
  6. Marmot
    If that 720 horsepower is produced at 2300 rpm then the torque is 1644 ft-lbs.
    torque = 5252 X HP / RPM
