Click for Delta Click for Burger Click for CL Yachts Click for Northern Lights Click for Nordhavn
871 Detroit Diesel Transmission rubbing when in gear?
Discussion in 'Chris Craft Roamer Yacht' started by dwelch, Jun 6, 2019.
  1. dwelch
    dwelch New Member
    dunnville , ont
    tested oil . all seemed fine / doesn't seem to make any difference running , but you can feel a rubbing , when in engine room cannot hear or feel anything , any ideas would be appreciated
  2. boatpoor
    boatpoor Senior Member
    Have you checked for line wrapped around the shaft between the wheel and strutt?
  3. Capt Ralph
    Could be cutlass bearing, shaft log, thrust bearing, flywheel adapter and/or more.
    Give us something to go on? What clutch? In gear forward and/or reverse?
    Like when did it start? After it was worked on or when you went over some shallow water?
  4. dwelch
    dwelch New Member
    dunnville , ont
    yes , its in the water now , but yes did thorough check on shafts , props, cutlass
  5. dwelch
    dwelch New Member
    dunnville , ont
    does in both forward / reverse , about a year ago , I noticed , I called Harper Detroit , mechanic said , test oil , that should give necessary info , but nothing ...flywheel adapter , that's sounds ominous ,
  6. dwelch
    dwelch New Member
    dunnville , ont
    I did blow a oil line in that tranny couple yrs ago , never went dry , just made a big mess , refilled oil , then changed oil again , seems fine , but yes that sound has come from that time frame ..
  7. Pascal
    Can you clarify your first post ?
    “but you can feel a rubbing , when in engine room cannot hear or feel anything , ”. Well which is it? Confused
    Can you turn the shaft by hand from inside boat?
    Are you sure the rubbing noise isn’t more like the pressurized oil making a noise
    Someone already asked what gear you have.... most 8V71s cane with Allison’s.
    So it doesn’t do it in neutral? Have you compared gear pressure with the other engine, in Neutral, Fwd and reverse? Any air bubble or foam on the dipstick? Assuming you have Alisons I doubt it s low on oil as the first symptom would be a delay in getting in forward
  8. dwelch
    dwelch New Member
    dunnville , ont
    can only feel rubbing from the wheel , no room to turn shaft inside , but did outside prior to launch all was fine , yes Allisons , just in gear not neutral .. will check next time leave the dock for foaming issue , and thanks
  9. Pascal
    Don’t forget that with Allisons oil level must be checked engine running at idle in neutral although I don’t think it s low pressure issue as explained above
    Does the oil look clean?
  10. dwelch
    dwelch New Member
    dunnville , ont
    oil looks clean , changed it last fall , and last spring , will check again this week , thanks
  11. dwelch
    dwelch New Member
    dunnville , ont
    now wondering if rubbing feel , s from drippless stuffing box , had installed maybe 10 yrs ago , been out about 3 hrs total this season , and found I had 2 quarts of water in container under stuffing box , so its leaking , not sure how to fix , or even check , could this be my rubbing feeling from the wheel ??
