Click for YF Listing Service Click for Ocean Alexander Click for Westport Click for YF Listing Service Click for Nordhavn
54 Offshore bridge drains
Discussion in 'Offshore Yacht' started by Craig Wilson, Aug 31, 2023.
  1. Craig Wilson
    Craig Wilson New Member
    Phoenix AZ/LaConner WA
    Bridge drains feeds into a 1 inch hose running down the wing structure support of covered walkway. Hose is inside of wing terminating in lazarette . Hose has hole in it and fills wing with water. Hose is secure and cannot be pulled out. Any one experience this and would know of a fix??
    Hose has (visible?) holes in it or an invisible fitting is loose?
    Or something else is leaking and you suspect the hose.
    Secured drain hoses do seem to last a while. Clamps and fittings don't.
    Have you talked with factory support yet?
    Since your original post on this in May had no replies, I had to type something. :cool:
  3. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Maybe try running a new hose through the original hose?
    -Chris
  4. Craig Wilson
    to small to sleeve good idea though.
