Click for Delta Click for Westport Click for Burger Click for Ocean Alexander Click for YF Listing Service
46’post replacing AC hoses
Discussion in 'Post Yacht' started by Damon Capozio, Nov 28, 2019.
  1. Damon Capozio
    Damon Capozio New Member
    Florida
    Replacing water hose going to AC compressor under forward bed.
    Try hooking the new hose to the hold hose with a hose barb to hose barb, and pulling it through.
  3. Damon Capozio
    Florida
    I’ve got a leak somewhere in the hose running along starboard side and it looks to be original.
    thank you Capt. J
  4. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    I have a 6' length of 3/8" threaded rod I use to get hoses and wires back into and through tight places/spaces.
    Just Wrap tape around your hose , wire or whatever ever , to the end of the threaded rod and poke, push away. It works well because the rod is fexable to bend and form into shape yet firm enough for press froward with your hose/wire to get to the other side such as a bulkhead or under your birth as you mentioned .
