Click for Abeking Click for Nordhavn Click for Ocean Alexander Click for YF Listing Service Click for Cross
45’ viking with weak stringers.
Discussion in 'Viking Yacht' started by Joey Pridmore, Sep 29, 2019.
  1. Joey Pridmore
    Joey Pridmore New Member
    Foley al
    I am looking at a 1990 45’ with soft stringers in the engine room. Should i be concerned and what would be a fix?
    YES, you should be concerned. The stringers are the backbone of the entire yacht. The fix is major and you would have to remove and replace and re-glass in new stringers. The cost is extensive.
  3. Joey Pridmore
    Foley al
    Can they be infused with epoxy? Someone said you can drill them and put epoxy into them. It is just in certain areas
    It's possible. But really a bandaid and not a cure. First you need to find out where the water is getting into the stringers, then fix that, then epoxy, but that's really IMO a band aid and not nearly as strong as a boat with proper stringers.
  5. Capt Ralph
    A Viking ??? with weak stringers?
    Who diagnosed this? A real surveyor?
  6. captholli
    captholli Senior Member
    In The Bilge
    1990 Viking with marine ply sandwiched over foam board , epoxied and glassed over. Depending on how much delam and moisture is present , I would proceed with caution. They're are companies that specialize in vacuum penetrating and drying out areas like stringers and then vacuum bagging and infusing the areas with resins. Look at past Ship Shape TV for the company that does this procedure.
  7. captholli
    In The Bilge
    Found it! Company is called Dryboat.
  8. Pascal
    Yes it s a big concern. Could cause alignment and gear issues. Some builders used the plywood as a structural part of the stringer. Not just as a core. So if you don’t have enough strength in the fiberglass just injecting epoxy isn’t going to be enough.
  9. Joey Pridmore
    Foley al
    I did.
  10. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    I would move on. Find another boat with a good keel/stringers ,Viking or whatever you interested in but not this one. There are plenty of other boats out there to fall in love with at a fair price.
  11. Capt Ralph
    Get the VIN and call the factory. They may confess the issue and the fix.
    However, Cleanslate has the real answer, move on.
  12. Capt Ralph
    If you have to have it, Find a laminate surveyor with experience in these issues.
    Be ready to tear the boat apart with engines and all out. Do you really want to buy into a long project?
  13. cleanslate
    Cherry Hill, NJ
    Where the hell are you going to find that ?! Good luck. It's hard enough to find a good mechanic or repair person that can do the most basic of things nowadays. I would be nice to find such a LOCAL person.
    Add to that every boat builder has its way of doing their stringers, along with changing their way of doing it through out the years....through trial and error and mostly ( save) cost and time .
  14. Joey Pridmore
    Foley al
    Bought the boat. After farther investigation its not as bad as i first thought. Repairs can be made easily. What type wood floor can i put in the salon? Came with blue carpet. Its got to go.
  15. Beau
    Beau Senior Member
    Beaufort, NC
    Try a beige carpet with a sound barrier pad beneath?? Teak and holly is nice to look at, but in a high traffic areas you are going to wind up covering it with a floor canvas or more, IMO
  16. olderboater
    Since you asked for advice on the stringers and didn't follow any of it, what is your solution for the stringers? Educate us.
  17. Joey Pridmore
    Foley al
    It is just part of one in the engine room. I am going to cut the top out of it. Clean it out and pour wet system epoxy in it
  18. Joey Pridmore
    Foley al
    I am wanting a wood looking waterproof material. I am going to insulate the engine room. Most of The reason for a wood type material is engine access. We can throw a rug on it.
  19. Pascal
    You can’t just pour Epoxy to replace rotten wood. It needs to be reinforced with a new core. Not only Epoxy isn’t structural but if significant amount of voids are filled the Epoxy will overheat while curing
    We recently replaced the salon carpet with some synthetic flooring that looks like wood on the 84 footer I run. Looks great. Extremely tough as we did two trips to the Abacos with thousands of pounds of boxes stacked inbthe salon. No scratches. Completelybeater resistant. I ll try to look up the brand. Only downside is that it is made in china. :(
