Click for Walker Click for YF Listing Service Click for Glendinning Click for Delta Click for JetForums
42' Post Sportfish info needed
Discussion in 'Post Yacht' started by brock71, Jul 3, 2013.
  1. brock71
    brock71 New Member
    chagrin River
    Looking at buying a late 70"s model. Nice boat. One question on construction, are the stringers built with encapsulated wood or are they 100% glass?
    Another question, the aft deck....balsa core?
    Any particular problem areas to investigate before I jump into this?
    John
  2. chesapeake46
    chesapeake46 Senior Member
    The 1980 model hed a balsa cored rear deck.
    Is the boat you are looking at gas or diesel ?
  3. brock71
    brock71 New Member
    chagrin River
    42 Post Question
    the boat is a 1978 model with diesels. 1200 hrs.
    Reported to have a soft spot in the rear deck at the base of the ladder. Not sure how extensive. Possible to repair from below without disturbing the glass deck?
  4. chesapeake46
    We had the same issue.
    Also had a little rot near one of the floor hatches.
    In the end we had the entire deck re-done.
    Where the through bolts for the ladder were located, we inserted solid glass rather than relying on bedding compound to seal the balsa.
    Diesels are a good thing.
    Some of them had gassers but I think anything over 40 feet oughta be diesel.
    The poor gas engines get whupped pushing a 42.
  5. brock71
    brock71 New Member
    chagrin River
    I'll look the rear deck areas over carefully. Thanks foer the tip.
    Can you comment on the hull stringer construction? Any wood to rot there?
  6. RT46
    RT46 Senior Member
    unless totally beat to death as a charter boat or badly neglected, a 42 Post with Detroits is a very good value in todays market.
    Any older boat is going to have some issues.
    If you find one that is too tired or priced too high, just keep looking.
    My current boat is a 46 Post and my only complaint is that is not a 50 Post.
  7. mwwhit1
    mwwhit1 Senior Member
    a
    As far as I know, the main 4 stringers running fore and aft are all glass with no wood. The cross supports to these main stringers are glassed over wood. Not sure if plywood or mahogany. There is always a possibility for rot in these if water was able to get in past the glass.
    All compartments are able to drain through the main stringers to the forward bilge pump. So the only water you should see is under the bow floor. Because of this, rotting in the stringer system is not that common.
  8. Miss Lisa
    Miss Lisa New Member
    Houma, LA
    RT46,
    I am looking at a 1984 Post 43' w/6-71 DD. It appears from the pictures to be very clean and well maintained. It has 2103 hours on each engine and a new Westerbeke generator.
    Asking price is $95,000. Given a good survey and engine survey do you think it would be a good buy?
