Click for Delta Click for YF Listing Service Click for CL Yachts Click for Westport Click for Westport
News: Aegean Yachts 37M Project 'Tempest'
Discussion in 'Unique, Custom or New Launches' started by Yacht News, Sep 15, 2023.
  1. Project 'Tempest' Under Construction At Aegean Yachts
    Project 'Tempest' is currently under construction at Aegean Yachts facilities. The 37-meter vessel is being constructed in steel for the hull and aluminium for the superstructure. Ample exterior real estate will be available with a long main aft deck and a secluded foredeck with small plunge pool. The upper deck aft is where most of the sunlounging will be done with this vessel thanks to the purpose built-in sunbeds there.
  2. A five cabin layout is expected and at double occupancy, 10 guests can be accommodated at one time. The breakdown showcases the master suite on the main deck which is full-beam and spacious while the guest cabins are on the lower deck comprising of two doubles and two twins. The decor in the cabins echoes the overall theme seen in the main spaces of the yacht. The interior design is by Riza Tanzu and as you can see in the renderings the idea follows beach house decor as the inspiration.
  3. You will find that she is going to be carrying a pair of MAN 1,325 Horse Power engines which will ensure Project Tempest will reach a top speed of 16-knots when required. However, to extend her range cruising is set at 13-knots. Her range is approximately 3,000 nautical miles. This yacht is presently available for purchase and is currently under construction with an estimated delivery time of June 2025. The price at present is 14,800,000 EUR.
    Aegean Yacht
    Yokusbasi , 3159 Cad. No : 4/1
    Bodrum , 48400 TURKEY
    www.***************
