Click for Walker Click for Glendinning Click for Abeking Click for Burger Click for Cross
News: 75M "Infinite Jest" Launched
Discussion in 'Turquoise Yacht' started by Yacht News, Mar 29, 2023.
  1. Turquoise Launch 75-meter "Infinite Jest"
    In Turkey another new yacht has touched the water. This time it is hull NB 69 from Turquoise Yachts called "Infinite Jest". The 75-meter superyacht has its lines drawn by the Vallicelli Yacht Design firm and an interior by the famed Sinot. The yacht was officially launched to the water on the 27th of March. The yacht should be completed later this year. The yacht was built with a steel hull and aluminum superstructure to satisfy Lloyd’s Register Of Shipping; +100 A1 Ssc Yacht Mono G6,+ Lmc, Ums. This yacht originally was supposed to have been delivered towards the end of 2021.
  2. Power is via a pair of CAT 3516C diesel engines which will power her to a top speed of 17-knots when needed. The tender carrying capabilities of this yacht is good with provisions for a 10.2-meter primary limousine tender, a dedicated guest shuttle, a crew tender as well as toy and jet ski storage in a full-beam midships garage on the lower deck. Special features onboard include a touch and go landing area on the bow, a terrace area with jacuzzi off the master, sizable beach club facilities on the aft lower deck that opens to the sea on three sides. There is a dip pool on the aft main deck as well. The design called for a sky lounge gym located on the sun deck with fully opening windows, that allow almost 360° vantage point from up high, allowing the guests to work out either enclosed or open air.
  3. Onboard you will find five guest decks above the waterline to serve (up to) fourteen guests. Seven cabins have been fitted-out for those guests that include the master suite which resides on a mostly private deck, a VIP and five other guest cabins. There are ten cabins for the twenty-one crew as well. At 75-meters and 14.2-meters wide with a 4.1-meter draft the yacht is spacious boasting an internal volume of 1,680 GT. One of the last yachts this yard completed was Project 'Tala' -known today as "Jewels"-. Coming up for the yard is the launch of Project 'Toro'- a 79-meter.
    Turquoise Yachts
    Güzelyalı Mah. Malkoçoğlu Sok. No: 3/1
    34903 Pendik, Istanbul, Turkey
    www.*******************
