Click for Ocean Alexander Click for Delta Click for Abeking Click for Westport Click for Cross
News: Ocean Alexander Reveals 35 Puro
Discussion in 'Ocean Alexander News & Launches' started by Yacht News, Nov 2, 2022.
  1. 35 Puro Revealed By Ocean Alexander
    Taiwanese builder Ocean Alexander has revealed a new model they have named the 35 Puro. This is something new while still building at the same size of their current OA 35 Revolution model. The first hull is already under construction and the styling by Giorgio M Cassetta points the design towards a European aesthethic. The model name 'Puro' suggests this as it is Italian to convey 'the essence of all things that are pure'.
  2. It appears that the Puro designation is intended to be the start of a new series for Ocean Alexander but for now the 35 Puro is what the yard is focusing on. Initially we said the first hull is in the works but two have started production. The first hull will be ready to be shown at the 2023 edition of the Fort Lauderdale International Boat Show (FLIBS). For power the 35 Puro is to be fitted with a pair of MAN V12 2000 engines.
  3. Onboard the vessel will be able to accommodate up to ten guests in five cabins. The master suite is to be full-beam and located on the forward main deck with expansive glazing on either side. Being the main bedroom onboard it will be fitted with a King bed and like the other cabins have ensuite facilities designed with heated stone floors. Walk-in closet and dressing areas can also be expected. The other guest cabins are on the lower deck and are divided into two twins and two VIP-category cabins. Five crew can be slept in three crew cabins.
    Ocean Alexander
    1001 Fairview Avenue North
    Seattle, WA 98109
    www.oceanalexander.com
