Click for Glendinning Click for Delta Click for Cross Click for Ocean Alexander Click for Abeking
News: Aegean Yachts Unveil In-Build M25 Explorer
Discussion in 'Unique, Custom or New Launches' started by Yacht News, Sep 29, 2021.
  1. In-Build M25 Explorer By Aegean Yachts
    A new tri-deck range has been initiated at the Aegean Yachts company called the M25 Explorer. The first hull is actually under construction utilizing a steel hull. As the model name suggests, it is a 25-meter vessel making it 82.5-feet long. The M25 will be the smallest of the range as the others are planned to be 37 and 48-meters respectively. While the first hull is being fashioned with a steel hull the yard suggests that all three model sizes can be built from steel or aluminum, dependent on what the owner prescribes.
  2. The design for these yachts has been handled in-house which represents exterior, interior and Naval Architectural work. Despite her relatively small footprint, there is plenty of deck space available to guests. Particular focus has been given to al-fresco living with ample built-ins for seating and huge sunpadded region on the aft upper deck.
  3. Onboard her 185 GT, the interior volume has the ability to sleep up to twelve (12) guests. That is odd, six (6) guest cabins onboard this 25-meter yacht. The breakdown of guest cabins is a VIP suite, two doubles and three full-beam suites. Up to six crew will sleep in four ensuite cabins. The interior decor is one that the owner has liberty with but the standard will feature dappled marbles and warm wood finishes. MAN power will be installed allowing for a top speed of 14-knots. Construction on the first M25 hull is expected to be ready for launch in the Spring of 2022.
    Aegean Yacht
    Yokuşbaşı Akdeniz Cad.
    Bodrum 48400
    www.***************
