Click for Glendinning Click for Nordhavn Click for Ocean Alexander Click for Northern Lights Click for CL Yachts
News: 65M Superyacht "Resilience" Launched At ISA
Discussion in 'ISA Yacht' started by Yacht News, Jul 29, 2021.
  1. ISA Launches 65-meter Superyacht "Resilience"
    ISA is the latest Italian yard to launch a new superyacht. This time it is the 65-meter superyacht "Resilience". The 1,400 GT superyacht takes its design from the folks over at Team For Design headed by Enrico Gobbi. This yacht once completed will actually make her world debut at the 2021 edition of the Monaco Yacht Show (MYS). Palumbo Superyachts, who now runs the ISA brand is immensely proud with how the build turned out and the owner had deep input into the process of the build. In fact, the name of the yacht stems from the resilience the yard and the owner and family displayed as part of build happened throughout the covid-19 pandemic.
  2. Onboard there are a number of features for the owner and family and guests to enjoy. In terms of accommodation the yacht has six (6) purpose-built cabins but there is a flex cabin space that can be converted into a seventh cabin it needed. The full-beam master suite is located on the main deck. The steel hull and aluminium superstructure construction houses an internal volume of 1,400 GT which is plenty value of space for the owner and family to enjoy. Some notable facets found onboard is a main pool on the aft main deck that has a contra-flow feature. There is another smaller pool on the forward sun deck. ISA says there is a gym, massage room with sea view, Turkish bath and an outdoor cinema room.
  3. For getting to and from shore when at anchor, there are two tenders for guests to use. Two jetskis are also available for play. The yacht has a dark coloured hull and similarly painted accent areas throughout the superstructure and mast. This owner came started this project back in 2017 and though faced challenges throughout parts of the build thanks to the pandemic this milestone launch showcases the determination and resilience needed to see the construction through to launch.
    Specifications:
    LOA: 65.5M
    BOA: 12M
    Draft: 3.3M
    Engines: 2 X MTU 12V 4000 M63
    Speed: 16-knots (MCR 100%); 14-knots Cruising
    Range: 5,500 nautical miles @ 11-knots
    Gross Tonnage: 1,420
    Accommodation: Up to 14 guests in 7 cabins (normally 12 in 6 cabins)
    (16 crew in 9 cabins)
    Materials: Steel Hull; Aluminium Superstructure
    Build: 2021
    Palumbo Superyachts Ancona s.r.l
    via Enrico Mattei 14
    60125 Ancona
    Italy
    www.*************
