Click for CL Yachts Click for Delta Click for Cross Click for Ocean Alexander Click for CL Yachts 99X
News: First EXTRA 93 Launched
Discussion in 'ISA News & Launches' started by Yacht News, Aug 21, 2019.
  1. Newly Launched EXTRA 93
    The latest launch from this Italian yard comes in the form of an EXTRA model. It is the first EXTRA 93 of this line to be launched. When completed this example will make her world debut at the Cannes Yachting Festival alongside the EXTRA 86. It will also make an appearance at the Monaco Yacht Show (MYS). You will find the work of Francesco Guida on the exterior and interior of this yacht.
  2. It appears the interior will sleep up to ten guests -at double occupancy- in a five cabin layout. The master suite is full-beam in nature and located on the forward main deck. The lower deck is home to two twins and a pair of VIP-grade suites. All cabins for the guests are ensuite as you would expect.
  3. The EXTRA 93 is using triple Volvo Penta IPS for power to propel the yacht through the water. Top speed is estimated to be around 18.5-knots. Construction is in composite and satisfies RINA and CE classifications it was built to. The color of this yacht on the exterior is pretty standard so it is possible this is just a show boat for now. If you are going to be at any of the upcoming boat shows, you can look out for her then.
    ISA Yachts
    Via Mattei 14
    60125 Ancona
    Italy
    www.*************
