Click for Glendinning Click for Westport Click for Abeking Click for Delta Click for YF Listing Service
News: Astondoa's 120 Century Flagship In Build
Discussion in 'Astondoa Yacht' started by Yacht News, May 20, 2018.
  1. Astondoa 120 Century Flagship​
    With the second Astondoa 110 Century hitting the water earlier this year the yard has its attention set on launching an even larger model, the Astondoa 120 Century. This yacht will pick up where the 110 model left off and be the crowning jewel in the manufacturer's range. The first hull in the 37-meter vessel model is actually under construction and expected to hit the water in the Spring of 2019.
  2. The Spanish yard has collaborated with Cristiano Gatto again and it is anticipated to be as good work as the 110 range. At 37.42-meters LOA, the beam is going to be around 8.30-meters or just over 27-feet. It appears that the accommodation will vary based on what the owner specifies. The master suite is in the traditional forward main deck position while as many as five cabins are understood to be allowed on the lower deck. Most persons will more than likely go with a four-cabin layout below deck though. The Century line includes a 90-footer, 100, 110 and now the 120-footer. The 110 has a maximum speed of 24-knots and a range of around 600 nautical miles. In the pipeline there may be even more room for an Astondoa 130. Astondoa did not have any particulars for the performance of the new 120 Century. Below is a photo of the 110 Century for comparison.
    Astondoa
    Muelle de Poniente S/N
    03130 Santa Pola
    (Alicante) Spain
    www.************
