Click for Nordhavn Click for YF Listing Service Click for Nordhavn Click for JetForums Click for Walker
1998 53 voyager rain water leak
Discussion in 'Carver Yacht' started by gw65vette, Aug 6, 2012.
  1. gw65vette
    gw65vette New Member
    masapequa n.y.
    i have a 1998 53 with a rain water leak that appears on the step to the pilot house near the 12 volt panel.has anybody had this problem.it just appears on the rug it is not dripping from above.
  2. sub-dude
    sub-dude New Member
    Kansas City
    Remove the DC panel and look inside the starboard salon wall towards the left (fwd). There is a screw there that holds the aft section of the lower pilothouse door track in place. I was getting water running down that screw and across the bottom of that interior cavity into the carpet area. You may be having the same issue.
  3. gw65vette
    masapequa n.y.
    leak
    Thanks I will check it out as soon as the boat is in the water.
    george
  4. gw65vette
    masapequa n.y.
    water leak
    Thanks that's the spot. but how did you get in there to stop it. at 270 I cant make it
    Thanks Again
    George
  5. sub-dude
    sub-dude New Member
    Kansas City
    After removing the DC Control panel I was able to reach forward and smear the hole left by the screw with some 5200. That seemed to do the trick.
  6. Water Leak
    I am having the same water leak problem with my 1999 Carver 530. I will have a look to see if I can correct the problem the same way as you described. Thank you for the information.
