Click for Glendinning Click for Nordhavn Click for Delta Click for YF Listing Service Click for Burger
1986 Ocean 55 super sport Forward Bilge
Discussion in 'Ocean Yacht' started by SeaStar, May 16, 2014.
  1. SeaStar
    SeaStar New Member
    Lyford Cay
    Has anyone had to replumb the forward bilge pump ? When the boat was built , they left out one major factor . Access to the bilge where the present plumbing runs . There is bound to be someone out there that is feeling this pain haha. mainly looking for a plumbing schematic really and some ideas .
    John
    Can you access the thru-hull discharge side and attach a hose mender to the new hose, clamp it and tape the clamps and pull it through? There should be access either through the closet or something to get to it.
  3. SeaStar
    SeaStar New Member
    Lyford Cay
    Ill look again , I would think there would be access as the hose runs from behind the settee to in front of the starboard fuel tank down in front thru the bulkhead . then I loose it under the cabin sole in the crews / guest cabin and find it again from under the starboard head . The hose turned to goo and of course has completely stopped up .
  4. K1W1
    When trying to pull hose through holes not much bigger then the hose I have found that shoving a short length of plastic or metal pipe into the respective ends and attaching with CSK Self Tappers or Pop Rivets will give you the smallest diameter and not as risky as using glue and having it pull apart mid job when your feet are on the bulkhead and you are doing tug of war on your own against the masses.
    Dish washing liquid also makes a good lube for the outside in tight holes through frames etc.
  5. SeaStar
    SeaStar New Member
    Lyford Cay
    I will give that a try . Never thought of using pipe ! I have a snake on order to get it past the starboard fuel tank and thru the Bulkhead but will give that a try
    Thank you !
