Click for Ocean Alexander Click for Northern Lights Click for Mag Bay Click for Apollonian Click for Nordhavn
1972 48ft Hatteras Yachtfisherman
Discussion in 'Yachts Up To 49'' started by REBrueckner, Dec 8, 2005.
  1. REBrueckner
    REBrueckner New Member
    Boat from New Rochelle, NY. Lately have been spend
    48.7ft x 14.6ft x 3.5ft, 45,000 lbs
    Turnkey condition (everything rebuilt or replaced), warranty available
    USCG documentation # 546387, 11ft Boston Whaler and lift
    Over $130,000 in upgrades, $10,000 in spare equipment & parts
    Records: Original equipment, upgrades and maintenance
    Refinished traditional teak interior paneling, Fiberglass f/b hardtop, full enclosure
    Dual heating systems and full air conditioning, all dual electronics
    Propane cooking, dual 12v refrigeration, 12v lighting,extra batteries: genny free cruising!
    Single aft stateroom: Custom queen, twin berths, desk, Anchor alarm in aft stateroom: Standard Horizon 150 WAAS chartplotter; forward stateroom with upper/lower berths.
    Engine Room: 435 HP 8V71TI’s, RACOR CCVs, Allison transmissions, RACOR filters with water alarms & vacuum gauges; coolant overflow tanks, video monitor on F/B, 1200w block heaters, spin-on oil filters; salt water flow alarms; transmission oil temp gauges, Powerline alternators with three stage smart regulators. 5 gal spare oil storage, oil change system for engines, transmissions & generator, rebuilt 12.5KW Onan generator, RACOR fuel filter with water alarm, remote temp gauge, 120amp and 130amp POWERLINE alternators, spare alternators, ammeters & voltmeters, manual combining switches and automatic hi amp combiners, smart regulators with battery temperature compensation; batteries: three banks, seven 8D deep cycle; Pathfinder combiner, 3 Statpower 40 amp temp compensated smart chargers, 2500 watt/130 amp dc Freedom Inverter/charger, 680gal fuel, 250 gal water, 85 gal holding tank, fully plumbed & alarm, Fireboy FE241 & CO2 automatic fire extinguisher systems & alarm monitor, multiple high water bilge float switch alarm sensors; 2 x 16,000 BTU Cruisair reverse cycle A/C
    Surburban 34,000 BTU propane hot air heating system Webasto 45,000 BTU diesel hot water heating system, Atlantic 12 gal hot water heater, electric & heat exchanger; fully heated and insulated
    Flybridge: fiberglass hardtop & twin hatches, full soft enclosure, radar arch, controls and complete (dual) navigation electronics, seating for five; Furuno 1751 radar on arch, Raytheon M40 on roof ,Interphase probe forward scanning depth sounder, Raychart 600 GPS chartplotter, RACOR water level fuel alarms, trans oil temp gauges, alternator output ammeters ; C-MAP NT electronic charts Wilmington SC thru Nova Scotia
    Robertson AP22 autopilot, Standard Horizon fish finder/digital depth sounder, water temp gauge; remote control bow rail mounted searchlight; two 20lb propane tanks with crossover harness.
    Bridgedeck (lower helm) ;Davis weather station (wind speed, temperature in and out),
    Interphase 7M GPS chart plotter, RACOR vacuum gauge readouts ;Raytheon R40 radar, Interphase probe forward scanning depth sounder, Speedlog (speed thru water) and digital depth sounder;fenders, circular table with four padded chairs;square table with four padded stool seats; remote control roof mounted searchlight; three 40lb propane tanks, crossover harnesses
    Cockpit: transom door, swim platform, h/c shower, washdown hose, winter cover & frame, 12v deck lights, 12v flood light, 4KW portable gas gen, Boston Whaler,S/S mast & boom Whaler lift, S/S whaler cradle, Magma Newport S/S propane grill, spare anchors, dock lines & fenders; deck box; two fender boards; Gasoline tanks: 1-12 gal, 2- 6 gal, 2-5 gal.
    Galley: 4 burner Maytag glass top propane, 1500 Watt microwave
    16 cu foot Frigidaire refrigerator, two Adler Barbour 12v refrigeration systems
    Heads: Two each with, shower, new sink and single lever faucet, new/rebuilt Raritan Crown macerator toilets,12 volt,120 volt lights,medicine cabinets,shelf storage, heat.
    Forward Deck: Two 48” deck boxes on forward deck, custom pulpit, Horizon Express windlass, 250ft 5/16” hi test chain, spare ¾” nylon, rail mounted searchlight
    Equipment not listed above
    7 bilge pumps, separate bilge water alarm system with five sensors
    Four anchors: Danforth T4000, T3000, Delta Fastset 55lb, 45lb, and lines
    Bow washdowns: deck mounted fresh & salt water, helm controlled pulpit mounted spray
    11 foot Boston Whaler, 10HP and 15 HP Mercury outboards
    Three stereo systems, three color televisions,
    Spares: props, stub shafts, water pump kits, belts, oil and fuel filters, lube oil, hydraulic fluid, many fittings, fixtures, outboard accessories, toilet rebuild kits.
    Three step dock box on wood platform,
    Covers: handrails, salon and bridge deck windshields, eyebrow side shades,
    Power cables: 1-50 amp, 2 -30amp, many connector adaptors,
    Upgraded original mast with cross arm anchor and new running light
    Nine USCG approved life preservers,
    Original Hatteras sales brochure, owners manual and technical& wiring diagrams.
    Custom sprayrails forward.
    Price: $169,000
