Click for Westport Click for YF Listing Service Click for Glendinning Click for Westport Click for Burger
'06 Azimut 50 + Kohler Genset = What relay?
Discussion in 'Azimut Yacht' started by Nudibranch, Aug 31, 2009.
  1. Nudibranch
    Nudibranch New Member
    Northland, New Zealand
    Hi there folks,
    Just got problem with our Genset's relay flicking and cutting power to the Genset.
    We have an Azimut 50 and Kohler 13KW Genny (think it's the 60 hz but not sure, We're in NZ if that gives any clues)
    So the relay looks as if the wire coils have at some point gotten pretty hot and slightly melted causing the relay to malfunction.
    When we tested the battery it's pumping out 13 volts at full charge. Could this have caused a relay rated for 12 Volts to become over loaded?
    If we need to replace this relay or possibly others too at some point. Can anyone point me in the right direction or give me a brand name of relay to look out for?
    Cheers and thanks for reading and thanks for your help,
    Tim.
    P.S it's the relay installed in the power box between the Genny Starter battery and genny not the relay inside the actual Genny itself but that might need looking at too, but I spose Kohler are the ones to ask about that one. yea?
  2. Nudibranch
    Nevermind, got it sorted.
