Click for Northern Lights Click for JetForums Click for Westport Click for YF Listing Service Click for Burger
Feature: Closer Look At Princess X95
Discussion in 'Princess Yacht' started by Yacht News, Jan 22, 2019.
  1. The Princess X95 Model Detailed
    Princess yachts used the 2019 Boot Dusseldorf to further detail one of the newest yachts in a new range of vessels they are offering. You might have heard about the X95 already but at the time last year when they released information on it, it was not comprehensive. Now we have a much more detailed look at the new X95 thanks to more renders being released and a lot more information coming to hand.
  2. A lot of emphasis has been placed on the exterior deck experience which is clear in the extensive space offered. From the flybridge to the fore deck there is decent space on offer for just plain relaxing or al-fresco dining. Below we can see how Princess envisions this space to be utilized. It is really another main salon, except outdoors without walls or interruptions, offering unparalleled vistas in the most comfortable setting. Of course the style of seating more-than-likely can be changed to allow owners to have a more custom look.
  3. Forward of the enclosed wheelhouse is also another area that will see significant use by guests. As a result of the extension of the main and forward upper deck areas, the X95 offers extra space ahead of the wheelhouse. As seen below, there is ample room for a large sunpad with integrated cup holders on the sides. Princess suggests that the sunpadded area can be optioned as a jacuzzi tub too. Additionally there is comfy U-shaped seating and a small coffee table to rest libations.
  4. One deck below you will find the main salon as well as the galley/dining area. The interior decor is alluring with a very light palette. The main salon uses neutral tones to create the illusion of larger spaces and free-flowing organically shaped furniture pieces further this concept. Instead of the usual hard and squared-off lines of built-in furniture following the set contours of the salon, the pieces seem to have more of a free-form feel and run to them.
  5. The master suite appears to be midships on the lower deck according to the Princess X95 deck arrangements but perhaps can be home on the forward main deck too. If on the lower deck, it comes with a large bed centrally placed along the centerline with a large curving dresser and coffee table to port. The ensuite features a double vanity whereas all the other ensuites to the guest rooms have single vanity setup. The ensuite in the master cabin is finished in white marble to keep the neutral and clean theme flowing throughout.
  6. The Princess X95 is going to be powered by MAN V12-1900 marine diesels. These powerplants should allow the X95 to achieve between 24 to 26-knots. The onboard fuel capacity will be in the region of 13,400 LT and fresh water capacity for 1,805 LT. At half load the X95 should be 104 tonnes give or take. Principle dimensions are 29.11-meters LOA, a beam of 6.77-meters and a full-load draft of 2.01-meters.
    Princess Yachts Limited
    Newport Street
    Plymouth, Devon
    PL1 3QG
    United Kingdom
    www.******************
