DELTA EXPANDS FACILITY TO ACCOMMODATE MORE AND LARGER PROJECTS...
Seattle, January 2005—Delta will complete construction of a new high-bay manufacturing and assembly building early in the first quarter of 2005. The new building is part of a three-phase expansion project that began in 2003.
Phase one of the expansion included the installation of a 400-ton Marine Travelift and boat lift pier to service the increasing demands of the Refit and Repair Division. Phase two includes the construction of a new high-bay assembly building, the addition of seven acres of land and the purchase of state-of-the-art machinery and equipment. Phase three will complete the project and include new offices for the in-house Delta Design Group, project management and the Refit and Repair Division. The entire project will increase total acreage to twenty-five acres and total enclosed manufacturing space to over 275,000 square feet...
Hatteras’ brand new H-68 Convertible wraps the distinctive nees of sportfishing into a dream-boat package, for the yacht owner who settles for nothing but the very latest innovations. No question; the H-68 is a yacht for the owner who is driven to be a force in sportfishing. These are very special yachts, for very special people.
The sportfishing yacht itself is a tricky challenge; it must deliver the speed and safety to get “out there”, the finest in cruising comfort, plus the most productive arsenal for finding and landing outstanding fish. Whether it’s for tackle-busting, a world-record marlin or Top Gun in a Release Tournament... Hatteras, a company with a half-century of credentials, delivers what sportfishermen want, and need...
Possibly one of the most interesting new launches of 2005 is Kelly Archer's new FPB 83, designed by Steve Dashew. More info will follow shortly, but the vessel is slated to launch on April 5th.
Here's the specs...
LOA: 83 feet
LWL: 81 feet
Beam: 17 ft 8 inches
Draft: 5 feet
Displacement: 100350 lbs
Engines: 2 x John Deere
Fuel: 2600 US gallons
Water: 1975 US gallons
Top Speed: 14 knots
Cruise Speed: 12 knots
Range: 9,800 miles at 10 knots
For further information, contact...
Kelly Archer BoatBuilders
P.O...
Here's the specs...
LOA: 83 feet
LWL: 81 feet
Draft: 5 feet
Top Speed: 14 knots
P.O...
MAGMA ANNOUNCES BIGGEST GOURMET GRILL...
Magma Products' newest and largest Gourmet Grill, the Monterey, boasts 420 square inches of grilling area—large enough to provide an onboard banquet for the hungriest of crews.
The Monterey's rectangular housing/grill area features 100% mirror-polished stainless steel construction, reliable Piezo ignition, double-lined inner safety shells, front-access lock-in, and slide-out grease trays. Closely placed grill grate struts keep small items from falling through the cooking surface.
The Monterey is equipped with an oversized, hinged, balanced lid to accommodate large cuts of meat, fish or fowl, but won't accidentally slam shut when the boat rolls. A stainless steel thermometer is mounted inside the grill lid. When not in use, all of the grill's components lock securely into place.
The Monterey uses readily available 1-pound disposable propane canisters, or easily adapts to onboard LPG (propane) or CNG (natural gas) systems...
ACTUATOR PLACES A SMOOTH RIDE AT THE FINGERTIPS
Glendinning Marine Products' Smart Actuator takes the fight out of balky engine and transmission linkage systems and gives boaters complete control of speed plus forward and reverse — with a single lever.
The Smart Actuator, used with Glendinning's Model CH2001 control head, creates a smooth arc of finely controlled power, even on throttles and gears linked by inferior-quality control cables. With Glendinning's Complete Control electronic engine control system, the boater can regulate speed and direction with accuracy and ease.
The EEC system with Smart Actuator provides sensitive throttle and gear response for sidling up to a dock, towing, anchoring or slow maneuvers that require precision handling. The EEC system utilizes CANbus interface technology, which simplifies wiring and allows greater flexibility when adding control stations...
PEERLESS PORTS PROTECT IN ALL CONDITIONS
Few port windows can claim to be watertight, provide varying, measured degrees of ventilation, ease-of-use and distinctive looks. But New Found Metals' Tri-Matrix, caulkless, self-sealing ports are that and more.
Made of 316/316L stainless steel and ABS weather - resistant copolymers, the port is light weight and strong. Stainless steel bands accent the interior and exterior rings while anchoring two cam dogs and a double hinge and the main frame’s polymer has UV inhibitors which resist fading from the sun.
Tri-Matrix ports are a good alternative for the boater who dreads going to battle with a messy caulking gun to replace old, unattractive port windows. The ports' bolt-through construction is engineered for a permanent dry-fitting as the plates compress a ring of closed-cell,
silicon foam to half its thickness.
The compressed foam seals the outside edges of the port from the elements...
PRESS RELEASE
Heesen’s First Launch of 2005
Oss, Holland – Thom Conboy is pleased to announce the first Heesen motor yacht launch of the year.
The 37 meter – 123’ Seascape was launched on January 7, 2005. This is the first of five scheduled launches for calendar year 2005 and the second vessel in the 3700 Series. Seascape is the sister to Lady Ingeborg which was launched in March 2004.
All vessels are built to ABS/MCA specifications. Heesen continues to be the premier builder in aluminum motor yachts in the 30 meters (123’) to 50 meters (164’) range...
Few yachts are as striking to behold as Kaiserwerft’s new “Perfect Harmony”. Sporting more curves than Mulholland Drive, the latest Baron 102’ completes a trilogy of launches by Kaiserwerft, who’s previous yachts include Ocean of Love and C’est la Vie.
The Baron’s somewhat fusiform shape embodies an anatomical form that can only be described as “shark-like”, with gills on each side and aft ledges reminiscent of dorsal fins...
BOATERS AND ANGLERS CAN NOW ORGANIZE GEAR IN STYLE...
Nothing catches the eye quicker than the glitter of polished stainless steel. To keep things close at hand and brighten the look of the cockpit, BoatMates Marine, a division of HCL Ltd., offers its new Tournament Series stainless steel Folding Drink Holder and Knife And Pliers Caddy.
Made from polished 304 stainless for timeless good looks and functionality, the Folding Drink Holder not only saves space, but also incorporates molded silicone fingers to adjust to varying sizes of cans, cups, cozies and mugs. A silicone coaster on the inside of the cover reduces noise and keeps containers from sliding.
For fishermen, the Knife And Pliers Caddy, also in 304 stainless, is great for keeping small tools, lures and lines handy and off the deck. Injection-molded ABS inserts protect tools and reduce noise...
Steve Barnett, Chairman of WorldSpan Marine, and Dan Fritz, founder of the Queenship Group are pleased to jointly announce that WorldSpan has acquired Queenship Marine Industries of Vancouver, British Columbia. Queenship’s new purpose-built 90,000 square foot production facility and shipyard, strategically located on the Fraser River 35 miles east of Vancouver, can accommodate the simultaneous construction of 10 yachts, as large as 150’ in length. The new facility also contains the largest paint facility on the west coast of North America.
WorldSpan is in the business of acquiring and investing in well managed strategic marine businesses that have a solid asset base, strong brand recognition, and outstanding prospects for growth...
Lucky number 7 in Trinity’s Victory Lane series is “Janie”, a classic, American-style 157’ tri-deck motor yacht, noted for luxuriant elegance and praised for allegiance to a particularly stylish mode. Janie is only one example of the many beautiful yachts built by Trinity, but her architectural allure is more than hull deep.
Marked by exemplary design as well as graceful demeanor, the lady Janie has managed a few departures from the norm and even enticed a new owner who could not resist her considerable charms...
Volvo Penta is now launching a new propulsion system for boats – the Volvo Penta IPS (Inboard Performance System).
The new system is proposed to make boats faster, stronger, quieter, cleaner and just as easily maneuverable as a normal passenger car.
In simplified terms, the new system features propellers that are turned in the direction in which the boat is traveling. Volvo Penta has placed pulling and counter-rotating propellers through the bottom of the hull, which provides the boat with significantly improved performance, compared with traditional shaft installations...
WITH ELONGATED BOWL, THE ATLANTES HAS THE COMFORT OF HOME...
For boaters that insist on the comforts of home while onboard, the Atlantes toilet from Raritan is available with an elongated bowl. Its larger seat size is far more comfortable than the standard marine toilet seat.
The residential-sized Atlantes provides an optimal sitting height. Nearly 3" deeper than a standard bowl, the sturdy, oval-shaped toilet offers a supportive, restful sitting area for maximum comfort. The extended rim length makes cleaning easier and improves sanitary conditions.
The electric macerating toilet conserves water through three flush options: normal, water saver and dry flush. It also has an adjustable, automatic timed-flush feature. Easy to clean and maintain, the Atlantes offers consistent, trouble-free performance. All working parts are contained inside the one-piece porcelain bowl for simple, flexible installation above or below the waterline...
CLEAT CHOCKS CATCH THE EYE BUT NOT THE LINE
Stainless-steel cleat chocks from New Found Metals are not only stylish and innovative, but are hand-polished so lines can pass through without danger of chafing. A cleat chock can function as a cleat, a chock or a fairlead.
The chock's horns are offset from the base at a slight angle, to lead the mooring line away from the hull as much as possible. The cleat chock can be mounted inboard or outboard.
Hand-polished cleat chock surfaces, especially the undersides of the horns, ensure uniform smoothness to virtually eliminate friction against secured lines.
The 316 Series comes in three sizes: 8", 10" and 12", with 3/8" x 2" studs on the first two and a ½" x 2" stud on the l2-incher. The smallest chock weighs about 2-1/2 lbs.
MSRP of the cleats starts at $39.95.
Contact:
New Found Metals
240 Airport Rd...
Contact:
New Found Metals
240 Airport Rd...
THE CABLEMASTER: ShorePower Made Easy
One way a boater can run afoul of the gear when docking or undocking is by wrestling with heavy, soiled, shore-power cables - and maybe wrenching his back in the process. With the touch of a button, Glendinning Marine Products' Cablemaster units will extend, retract and store many different sizes of shore cable, keeping them out of the water and the decks free of excess coils of cable.
Cablemaster comes in three models and can handle 30- to 200-amp cables. Time-tested Cablemasters, widely accepted by major yacht manufacturers worldwide, handle cables up to 2 inches (50 mm) in outside diameter.
Unlike industrial reels, the Cablemaster system does not carry shore power through slips rings or brushes, which can be susceptible to moisture or corrosion in a harsh marine environment...
Sunseeker has launched a real Predator in the luxury yacht market, stalking the super-fast yacht class with the fluid shape of a leaping dolphin. Sunseeker’s Predator 108’ breaks the surface in perfect animation… and an astonishing 43 knots!
With a radiant profile and dorsal fin ledges, the Predator possesses a surplus of Sunseeker’s slick styling, accented by a forwardly aggressive stance and a refined finish that challenges any creature of the sea...
At Lazzara Yachts, forward-streaming tear-drop windows sweep into the sleek lines of Lazzara’s latest yacht introduction, the 68 Sport. But the accelerating super-model look only hints at her inside story. This sporty yacht boasts more interior volume than most any other yacht in her class.
She’s immediately recognized and welcomed into the exotic Lazzara fold in the spirit of speed, comfort, performance, and contemporary fashion. When it comes to curves, the Lazzara’s have all the angles. Join us for a review of a yacht that accentuates the Lazzara’s boat-building lineage...
CMN are delighted to announce that they have been awarded the contract to build the new BERMIE. The 190' / 58m will be delivered to this repeat client in September 2006. The Owner has appointed Andrew Winch Designs to create the interior and exterior of the yacht which will have an Owner's cabin with forward facing panoramic windows. “The best ever view of the sea is a key feature of our design” - stated Andrew Winch.
CMN is very excited about this project which further confirms their reputation as a builder of fine super yachts. The team looks forward to receiving the same industry plaudits as former BERMIE did following her launch in 2001...
Millennium Superyachts, with a stable boasting rakish titles of adventure thrillers, like Thunderball, Octopussy and Moonraker – has now debuted what may be its most Machiavelian superyacht offspring yet, in “The World Is Not Enough.” The Millennium 140’ is a yacht that exceeds it’s action, adventure-flick namesake and just might become the catalyst for a whole new movie sequal.
The brainchild of John Staluppi, who’s previous titles also included the world’s fastest yachts, the M-140 has taken yachting into the new Millennium, literally… with a 75 mph rocket-yacht that is both speed and luxury... defined. Join us for the world premiere of a yacht so fast... film crews had to increase camera-shutter speeds to catch it!.....
From B.I. -
FORT LAUDERDALE, Fla. – Platinum SuperYachts has signed a definitive agreement with a private lending group to provide the company with $16 million in funding, the company said in a release yesterday.
It will use the initial proceeds of the financing for a state-of-the-art yacht building facility to begin construction on its range of semi-custom motor yachts for the global market. This is the culmination of management’s continued commitment to build the company into a world-class yacht builder, while focusing on and finalizing specific acquisition targets, Platinum said.
“The strategies and framework that we have implemented, combined with our association with the financing group will enable the company to achieve our corporate objectives in this vast ocean of opportunity for growth in the yachting world,” said Ron Ruskowsky, president and CEO of Platinum...
Page 167 of 168
