Click for Abeking Click for Ocean Alexander Click for Delta Click for Westport Click for YF Listing Service
zinc anodes - factors affecting speed of sacrification
Discussion in 'Technical Discussion' started by balboa, Oct 6, 2007.
  1. balboa
    balboa Guest
    Can anybody tell me which factors affect the speed in which zinc anodes are sacrificed?
    I assume it has to do with the conductivity of the seawater? If so, which factors affect that conductivity and are their other factors?
    Thorwald
  2. C4ENG
    C4ENG Senior Member
    Ft Lauderdale
    More to do with the amount of dis-similar metals in the sea water on the vessel
  3. Northern Lights
    Northern Lights New Member
    San Diego
    zinc burn rates
    Load and or demand to do work. One can reference exacted engineering to design a sacrificial anode sytem that the anodes burn at a predicted rate. The specific ratio of anode to metals that are being protected can be measured and from this one can design a system that protects the underwater metals from haul out to haul out. The ratio can change by many factors such as coatings failure and natural wear on the coating system. Failure of the hulls coatings expose metal that increases the demand on the zincs to do work. In a perfect world you would coat the metals so perfectly that there would be little or no demand on the zincs to do work. This never is the case. The installation of diver serviceable zincs allows for a variable. If you put to many zincs on a hull the demand is so low that the zincs often stop working as they create a coating. The coating (passivication) inhibits the the zinc from working. U.S. Mil-spec zincs contain a small percentage of cabnium to avert this. With the cabnium the zincs have a burn rate regardless of the demand. The electroguard zinc uses a dolphin with a gas mask on as there logo. Electroguard zinc contain no cabnium. Enviromentist agencies say that cabnium is not good in the food life chain.
    The boat yard can usually advise you based on expierence how many zincs to use. The most important link to your underwater metals is a underwater hull cleaning service that advises you monthly. Even with a new hull painting it is important to keep an eye on the metals below the waterline.
  4. balboa
    balboa Guest
    zinc anodes - impressed current cathodic protection
    Great feedback!
    Thanks a lot.
    So, would you say a ICCP system worth considering? Probably higher initial cost but down the line, it offers more secure protection it seems.
    Does it have any other drawbacks?
    Thorwald
  5. Highlander
    Highlander New Member
    Milford CT
    ICCP and zincs
    The great thing about the ICCP system is continous monitoring.
    My boat has zincs too and over 8 seasons the system has alerted me to a few problems.
    Stray currents from other boats/docks.
    High rate of wear on the zincs.
    One year the yard painted over the titainium pad with bottom paint.
    In all cases the unit showed either over / under protected.
    Its a lot easyer than diving
