Click for YF Listing Service Click for YF Listing Service Click for Abeking Click for Nordhavn Click for Northern Lights
Viking 1977 35 replace windows screens
Discussion in 'Viking Yacht' started by Viking 1977, Jul 7, 2017.
  1. Viking 1977
    Viking 1977 New Member
    st louis
    Trying to replace windows screens and we can not figure out how to remove the screens, the track is metal and we need to replace the felt inside as well. Any ideas?
  2. RT46
    RT46 Senior Member
    The rear track has screws in the center of the aluminum channel.
    remove the screws and remove the aluminum channel.
    then slide the window pane and/or screen to the rear section and remove.
  3. Viking 1977
    st louis
    Do we do this from the outside or inside?...thanks so much.
  4. RT46
    RT46 Senior Member
    inside, the top track comes out after you remove the screws.
    then slide the window panes and or screen to the rear section and it will tilt inward, then remove.
