Click for YF Listing Service Click for Cross Click for Delta Click for Burger Click for Walker
Post Gel Coat Issues
Discussion in 'Post Yacht' started by mmitchellnh, Oct 19, 2020.
  1. mmitchellnh
    mmitchellnh New Member
    Newburyport
    Can anyone tell me what year Post had there Gel Coat issues?
    Michael
  2. Beau
    Beau Senior Member
    Beaufort, NC
    I know it started in 1998 . I think it was cured by 2002. Maybe it was 2000? I'm getting old. Post identified, I believe it was 36/37 boats that had the issue. Fixed some, but not all before bankruptcy. The vessels not repaired by the Post or the boat owners themselves at another yard are quite apparent.
  3. Soulstice
    Soulstice Member
    Portsmouth, Ri
    As Beau mentioned, it is very obvious if a boat came from the bad gelcoat lot when you see it. I have seen them and you can notice It from a distance. Also it should be noted that not all boats from that time period have bad gelcoat as I have owned a 2000 and a 2001 both with good gelcoat.
  5. mmitchellnh
    Newburyport
    Thank You
  6. C team
    C team Senior Member
    Kent Island
    Post began purchasing and using CCP's 953 series gelcoat in 1997.
    Post built 81 boats using the 953 Series gel coat, and claims that in 2002 it began seeing massive cracking in 32 boats that were built between 1998 and 2002 and used in winter climates.
  7. FL000
    FL000 New Member
    New Jersey, USA
    Would you happen to know if there's a list of hull numbers for the affected boats? I've searched the court documents from the lawsuit but don't see anything. Thanks
  8. C team
    Kent Island
    No I don't have that info but maybe Worton Creek Marina might since they bought the Post assets.
  9. FL000
    FL000 New Member
    New Jersey, USA
    Thanks, I called and left a message for Patrick this morning.
  10. MagyMay
    MagyMay New Member
    Key Largo
    I just purchased a 2003 55' Viking SportFish Convertible and IT WAS ONE OF THE AFFECTED ONES! Unfortunately the original owners never looked into it or maybe it started happening after... Who knows! But I do have spiders EVERYWHERE...
  11. Quality Time
    Quality Time Member
    Upper Chesapeake Bay
    Hull #90 of the 50's was the last to use the CCP 953. They switched to Interplastic after that with no further issues.
    Soulstice likes this.
