Click for YF Listing Service Click for Delta Click for Abeking Click for Burger Click for Walker
Peggie Hall e-mail
Discussion in 'Technical Discussion' started by JohnHansen, Nov 22, 2021.
  1. JohnHansen
    JohnHansen New Member
    Denmark
    Hi!
    I'm about to replace a VacuFlush system with new macerator toilets and would like the advice from 'head mistress' Peggy Hall. On her Facebook side, she writes that she will reply to e-mail only. But does not state her e-mail adress.
    Does anybody know har e-mail adress and could share it?
  2. olderboater
    First, for spelling, her name is Peggie Hall. I would recommend buying her book on Amazon, available for $8.99 on Kindle. Otherwise, private message me and I can give you a means of contacting her.
    JohnHansen likes this.
  3. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    Separately, I got rid of my two vacu-flush heads and replaced with the Raritan macerator units. Happy to help if I can. It’s a pretty straightforward swap. I did a thread on it here on the forum. Biggest challenge is accessing everything but maybe not a problem for you depending on what boat you have.
    menkes and JohnHansen like this.
  4. JohnHansen
    Denmark
    First of all, sorry for getting the spelling of her name wrong - that is really impolite! I have bought her book and also read quite a few of her answers in different forums to different question. Regarding e-mail: I'll PM you.
  5. JohnHansen
    Denmark
    That sounds reasuring! I appreciate your help. Actually I'm not only replacing the 2 toilets, I'm also replacing the holding tank - I got one built to size by Tek-Tanks in the UK (polypropylen) - 134 liters/35 gallon - where I got nuts fixed on top of the tank to directly fit the two 3-way valves on top of the tank to minimize the length of the sanitary hoses. Removing the vac-pump and the vac-tank and the 2 'cross-boat' sanitary hoses will shorten the sanitary hoses of each toilet with around 3-4 meters!
    I have my heart set on the Planus Match toilet - do you know how that with reapect to function, quality and silent operation conpares to the Raritan Elegance (have just found out that there is a Raritan dealer i Germany, just 3 hours from where I live - maybe I should take the Raritan Elegance into consideration).
    Have you installed a vented loop in the discharge hose from the toilets? My boat is a Princess 60 from 1998 - the toilets sits on a small 'step' and the top of that step is around 10 inch above the waterline. From there it goes directly down to the 3-way valve on top of the holding tank in the center bottom of the boat and then 99,99% of the time directly into the holding tank. I have the possibility to switch the 3-way valve and let the discharge continue to a sea valve for direct into the sea discharge. But normally this sea valve will be closed and the 3-way valve will lead the discharge into the holding tank.
  6. DOCKMASTER
    Ketchikan, Alaska
    I did not install a vented loop. In fact, I removed the old siphon breaks which greatly reduced my hose length. I'm routed directly from the heads to the wye valves and into the tank or directly overboard. Most of the time mine is routed directly overboard.
    So far, I couldn't be happier with the Raritan units. I wish I would have done this swap several years ago. I also put in the SEA/Fresh option which is great. Allows me to switch from seawater to freshwater at the flip of a switch.
  7. Pascal
    I replaced the 25 year VFs on my 53 with Raritan elegance. Straightforward job bumpy just removing the vac tanks and pumps. I think I replaced one section of hoses and just used connectors where the vac tanks and pumps where
    I ve never understood the point of having y valves and direct discharges since they can only be used far offshore. More hoses, extra valves etc. I prefer to run waste to the tank and then used an overboard macerator when allowed.
  8. MichaelZ
    MichaelZ New Member
    San diego
    Peggy
    Can I use 2” exhaust/water hose (Triton) in place of sanitation hose. This is for holding tank to theough hull fitting
  9. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Peggy doesn't monitor this forum, but I don't think she'd approve of that choice, stick with Saniflex or similar
  10. Capt Ralph
    Yes but poorly.
    You would think exhaust hose, dealing with hot exhaust gasses and fuel chemicals would hold up to everything, But I would not us it for black water.
    Exhaust hose is not made to hold up to these extreme bio issues.
    FYI; black water is alive. Had me on my back for 10 weeks with blood poisoning.
  11. menkes
    menkes Member
    Aretsou, greece
    johnhansen.69235
    i changed all!!! my sanitation hoses in my yacht
    if you want to save yourself troubles by the best you can find and don't try to save a penny !!!
  12. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Just yesterday in another forum, she said Saniflex is the only sanitation hose she recommends these days. (We used Saniflex in a sanitation system upgrade, and found it very easy to work with.)
    And she said most systems use 1½" hose.
    -Chris
  13. rtrafford
    rtrafford Senior Member
    Vero Beach
    Agreed. Raritan macerator devices. Nice outcome knowing that if something fails, use another head. It doesn't require an engineer to keep it running.
