Click for Abeking Click for Ocean Alexander Click for Nordhavn Click for Westport Click for YF Listing Service
Orbital sanding toe rails and brightwork...
Discussion in 'Technical Discussion' started by rtrafford, Apr 28, 2020.
  1. rtrafford
    rtrafford Senior Member
    Vero Beach
    Here's another new one...have your maintenance team bring an additional tank with them. No need for the compressor. Have them hook it up in tandem with the 3 to 10 gallon tank already aboard, and the added capacity has them efficiently using pneumatic sanders on your brightwork.
    I actually went and purchased a new 5 gallon compressor for the last varnish effort. When we finished, I took the compressor off the newby and reinstalled it to update the unit aboard, complete with new mounts for sound improvement. Pretty easy swap.
  2. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    Cringe! We only hand sand our bright work.
  3. NYCAP123
    +++Ditto. Takes the grain off.
  4. rtrafford
    Vero Beach
    Sure, if you use 60 grit. We don't.
  5. NYCAP123
    It's not the meat it's the motion.
    This, plus you end up rounding off edges and stuff with power sanders. Varnish is easy enough to hand sand. I'm very good at varnishing, but haven't varnished a boat in years and do NOT miss it.
  7. rtrafford
    Vero Beach
    No need to educate me on a beautiful process we've carried on for years. We pneumatic orbital sand with 220 grit every three to four months, re-coat one coat to dry, orbital at 400, then add two finish coats with a splash of thinner. We maintain that appearance and don't go near wood grain unless a larger issue causes a need for a repair. If you stay on the varnish, you never go down to the wood, and it always looks like it's been sprayed on.
    But that's ok. You knew that, too.
  8. rtrafford
    Vero Beach
    You'll have a hard time burning up your wood with 220-400.
  9. Capt Ralph
    When we first pulled our Bert, I had an old Compressor onboard and an old vertical tank compressor from my garage next to the boat. Neither one very good but when charged together, the volume worked great.
    With them both hooked up directly to each other, the regulated air could just push two DAs for sanding the bottom before paint. The air was just getting low when your arms were giving out. Rest your arms, sip of drink, compressors cycle off, sand again for another 10 minutes over head,, repeat..
    We worked over some tarps that week. Never again.
    Tarps weighed a ton when we dragged them to the dumpster to spill the old bottom paint dust.
    That's when I learned many (MANY, MANY) coats of bottom paint does ad weight to a boat.
    After then, Huckins sands whats left of the ablative bottom with their vacuums attached, just to the S/W epoxy Barrier coat.
    Later, found this great 35gal compressor at a pawn shop. Was installed a week later. Been perfect for over 10 years now.
    Every time an air tool starts to mess up, down Pawn Shop Row (Blanding Blvd in Jax) till I find a good replacement. Never been disappointed, always a great deal.
    My air tool grave yards are scattered all over the Jax water ways..
  10. rtrafford
    Vero Beach
    Reads like the theory of doing business with Harbor Freight...lol...
  11. Capt Ralph
    No, No, No..
    I get Mac, Snap On and other better brand tools, near new, on Da Row, at a fraction of the price. I'm sure some glow in the dark, not a problem of mine.
    I get lots of cheap moving blankets from Harbor Freight. When dirty, I leave them on the dock or street side,,, gone in 5 minutes..
  12. chesapeake46
    chesapeake46 Senior Member
  13. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    I've done this for years too. Yup it works well. I use 400 grit and one coat. Only electric sand on the flat surfaces. Hand sand , like hand rails or curve sections.
  14. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    Until you discover the new cordless wonders.... oh baby.
  15. Ken Bracewell
    Somewhere Sunny
    I don't mean to derail the original topic. As a guy who grew up on wooden boats, and has been the professional captain on two of the prettiest "varnish farms" afloat, I would bet that I could pick out a piece that's been power sanded vs hand sanded.
    I'm currently applying 6 coats to about 1000' of cap rail on Berilda. Something we do twice per year.
  16. T.T.
    T.T. Senior Member
    S.F.
    Ken,
    Always like to hear what others use and details on technique. Purple 3M between coats?
    Apologies on the derail bump! Compressed air very handy onboard.
  17. Ken Bracewell
    Somewhere Sunny
    ScotchBrite Pads
  18. YachtForums
    Gents, I split the above posts from the discussion on air compressors.
  19. T.T.
    T.T. Senior Member
    S.F.
    Carl, again, my apologies. Ken has sage advice and I couldn't resist! A result of your dedication and collection of an experienced knowledge base.
    Thank you for your efforts
  20. YachtForums
    No apologies! Threads sometimes veer off course. It's the nature of forums. :)
