Click for YF Listing Service Click for Glendinning Click for Abeking Click for YF Listing Service Click for Westport
ONAN vs Kohler
Discussion in 'Generators' started by comship, Apr 7, 2007.
  1. comship
    comship Senior Member
    Greece
    Whats your opinion and experience from both manufacturers? Recently I heard that Onan is much more reliable than Kohler which have many electronic problems
  2. AMG
    It may depend on the size since they are based on different engines. I have had a 16 kW Kohler that was very reliable and above all, silent.
  3. comship
    Greece
    We are intending to install 2 x 40kW plus 1 x 22.5 kW
  4. AMG
    Have a look at Northen Lights as well. We had a couple of 33 kW that was working very well and when spares was needed (failing starters) they were delivered swift to where we were. Service is always good to consider.
  5. comship
    Greece
    The Engine Room is very small to house 2 Northern Lights 40 kW and 1 22.5 kW. If I had the space no question I would install Northern Lights
  6. comship
    Greece
    On the other hand onan use Cummins Engine and Kohler John Deer
  7. RVN-BR
    RVN-BR Senior Member
    South Florida & Mediterranean
    If I'm not mistaken, some Kohler gensets use Yanmar engines... at least thats what my captain told me iirc...
  8. AMG
    Yes, the Kohler I had was a Yanmar and the Northern Lights were John Deere.
  9. comship
    Greece
    Maybe I am wrong but anyway I heard that the new models of Kohler are having many electronic problems
  10. RVN-BR
    I have owned a few and havent heard and/or experienced what you report... I might have been lucky (knock on wood)...
  11. nilo
    nilo Senior Member
    Istanbul
    Kohler uses Yanmar up to 27 Kva gensets and above that they use John Deere engines.
    I have used 3 different gensets in the last 9 years and did not face any electronic problems at all, although using them at low rpm's (low loads) causes accumulation of residue, which ends up with unburned fuel at the exhaust discharge. However, I reckon this is a common problem for all diesel genset and engines.
  12. BMcF
    BMcF Senior Member
    Maryland
    The last Onan 18 I rebuilt was a Kubota diesel..I believe that most of the Onans up to 'some' larger size have Kubota engiens. I have found little to no difference between Kubota and Yanmar as far as the engines go, frankly. Both are good engines overall and very similar in every respect. As for the electrical/electronic side of any genset..I can't speak to that since I don't know enough about them.
    And I was under the impression that all of John-Deere-label diesel engines up to about 25 or 30 kw were Yanmar's regardless of whether it was a lawn tractor or a marine application. But I could be wrong, of course...:)
  13. comship
    Greece
    Thanks a lot guys for your kind assistance
  14. nilo
    nilo Senior Member
    Istanbul
    I have noted, I've missed stating that "I have used 3 different KOHLER genset"
