Click for Walker Click for JetForums Click for Abeking Click for Northern Lights Click for Nordhavn
Low load operation
Discussion in 'Engines' started by Dan balmer, Jul 6, 2020.
  1. Dan balmer
    Dan balmer Member
    Port Canaveral,fla
    Hi all. Was wondering about low load operation for economy to the Bahamas on 50 Post with Mtu at idle speed of 7 at 1.8 mph and the ramifications of doing that. That’s 1.8 nmpg
  2. BRyachts
    BRyachts Member
    Ft Lauderdale
    Shouldn't be an issue for a short run like that. Maybe bump them up to normal cruise speed occasionally, or a short hard run just before pulling into port to get the temps and pressures up to normal for a bit.
  3. Dan balmer
    Dan balmer Member
    Port Canaveral,fla
    I wanted to make sure that I m not pursuing a false economy whereby the charge air coolers or turbos or whatever are compromised somehow. I just got thru removing and sonically cleaning the coolers which were quite contaminated and that job on these MTU was quite the project.
  4. Pascal
    Many boats are often run at hull speed. As long theyb stay at operating temp, it’s fine. I usually run them up to cruise for 15-20 minutes after a long slow day.
    I believe you have 8v183's. I wouldn't run them at dead idle all of the way to the bahamas, but you should be fine at 800 rpms and even better at 1000 rpms. Then again I bet your boat spent many a day trolling around at idle rpm's with ballyhoo's behind the boat. You'll get great mileage at 1000 rpms but even better at 800 rpms. I'd run them 800, then run them up to rated fast cruise for 30 minutes every 6 hours.
  6. mapism
    mapism Senior Member
    Sardinia
    The exact model (TE92/657hp or TE93/756hp) might make some difference.
    I agree with your suggestion of avoiding dead idle with the latter, but for a whole bunch of reasons, I wouldn't mind doing that with the former.
  7. Dan balmer
    Dan balmer Member
    Port Canaveral,fla
    Engines are 8/183/93@756 hp. Thanks for your responses I have a clearer understanding of how to view this idea.
  8. Bill 32
    Bill 32 New Member
    Jupiter, FL
    I tried it years ago when fuel was high. If you're going perpendicular to the Gulf Stream you will end up just pointing into it and not making much progress and hence not saving much fuel.
  9. NYCAP123
    Very good point. From Miami you can just head a bit south and play the current, but from Canaveral he'll be fighting it the whole way. Bring the throttles up.
  10. JWY
    JWY Senior Member
    What does MTU have to say about your specific engines? Maybe also call the engine surveyor who surveyed them for you at purchase.
  11. Soulstice
    Soulstice Member
    Portsmouth, Ri
    The 50 Post is a SportFish with engines normally designed for long days of trolling at hull speed. I would just agree as others have said, bring the RPM’s up and run the engines at a cruising speed for 20 min or so before you get to your destination. This will heat your turbo’s up, clean out soot build up, etc.
  12. Capt J
    On the way back with the current it would be good to go slow.
