Click for Nordhavn Click for JetForums Click for YF Listing Service Click for Abeking Click for Burger
interior finish on a Post
Discussion in 'Post Yacht' started by Beau, May 8, 2018.
  1. Beau
    Beau Senior Member
    Beaufort, NC
    So folks, help me out. What type of finish was applied to my 1998 Post interior teak? I thinks its more than varnish....
  2. Davidoc
    Davidoc Senior Member
    Winter:Delray Beach, Fl Summer: Bahamas
    Here is an actual response from Post from back in the day. Mine is a 91 but I believe they stayed with this program for a number of years after that.
    Stained Pilot Houses, Doors & Drawers are McCloskey's Tungseal, Walnut Penetrating Wood Stain or Dupont Barnwood Stain ##1045C.
    Exterior - - - Bridge Parts & Moulding around shelter are Teak finished with Dolfinite#110 Spar Varnish.
    Teak treated with Tip-Top Teak (or equal) Mfg. by Tripple T. Enterprises, Inc., Palm Gardens Fla.
    Engine room - - Interlux #289 Miami Tan & 50% Z-Spar #105
    Boot Stripe - - Awl Grip Colors to Suit from chart
    Teak Interiors are sealed with Interlux sanding Sealer #X9297 then finished with #60 Interlux Rubbed Varnish
    David O'Connor
    561.386.2692
  3. Beau
    Beau Senior Member
    Beaufort, NC
    Thanks Davidoc. My interior is a high gloss finish with a very hard surface. I suspect it is not a varnish....
  4. mwwhit1
    mwwhit1 Senior Member
    a
    Hopefully someone has a Post manual that may specify. Post and Viking used many similar things back then. I wouldn't be surprised if it matches Viking, if you can track it down that way.
  5. Beau
    Beau Senior Member
    Beaufort, NC
    I have all the manuals, unfortunately I can't find any spec on it. I may just have the marina's refinisher stop by and give me his opinion....
  6. sigarn
    sigarn Member
    Wilmington NC
    I think you will find that most interiors in modern day boats are a 2 part urethane system that's sprayed on. There are a number of commercial brands they use but hard to buy as an individual.
  7. sigarn
    sigarn Member
    Wilmington NC
    Heres an example of the type of product I am referring to for interior finish that the builders use.
    DuPont™ 18320S™ & 18321S™
  8. Beau
    Beau Senior Member
    Beaufort, NC
    That was my suspicion...
  9. Beau
    Beau Senior Member
    Beaufort, NC
    I bought my 1998 baby when it was a little over 2 years old out of CT . My family has had a great ride with this vessel, but after a while you can't help but develop a nick or two here and there. I'd like to fair those away?
  10. RT46
    RT46 Senior Member
    This might be helpful.
    below was cut and pasted from a 1988 46' Post owners book:
    The book appears as though some of the info is for older 43 and 46 Posts's.
    The book does not reference the 50 Post. I am not sure when the 50 started production.
    FROM BOOK:
    " Paint 43' and 46' "
    Entire Exterior of boat is Interlux Exterior Gloss White #87, Mixed W/Ivory Interlux#224 (approx 8 oz/Gal.) to match Gelcoat.
    Inside Colors are tinted using the Z-spar Gloss#100. Wood finished with Interlux#60 Rubbed effect Varnish.
  11. Beau
    Beau Senior Member
    Beaufort, NC
    Thx RT. Production of the 50 started in 1989. Definitely a high gloss finish. And I'm almost certain it's a 2 part something or other. Too hard to be varnish
  12. My Affair
    My Affair Member
    Mystic, CT
    Where do you find Interlux #289 Miami Tan, I need to do some touch ups in my engine room?
  13. captholli
    captholli Senior Member
    In The Bilge
    I'm not sure if Interlux produces Miami Tan in their enamel line anymore. You can get custom tint paint from shops like Kirby Paint in MA. that will produce Miami Tan for you by the order. You might give the paint rep @ Jamestown Distributors in R.I a call and ask if they have a local source.
  14. captholli
    In The Bilge
    Apparently Kirby's has Miami Tan as a production color and in stock. George Kirby Jr. Paints in New Bedford, MA. produces vintage colors for restorations amongst their custom color tints and more than likely could answer all of your questions for interior rubbed effect or high gloss finish for Post Yachts . Ask for Bill or George and you'll be impressed with the knowledge and excellent customer service from this 100 yr old + Co.
